Question about GE Audio Players & Recorders
Date code 3:0004 on GE 7-4612A
I am trying to determine when my gas range was manufactured - 362-7585590 is the model number. And who manufactured it. Thank you.
The 362 code indicates that the range was made by GE. The manual for the range is available here: http://www.searspartsdirect.com/partsdirect/user-manuals/3627585590-kenmore-parts-gas+range-manual?manualIndex=0 . To download the manual go to http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0801065.pdf . You need the serial number of the range to determine the date of manufacture.
These sites may help: http://products.geappliances.com/appliance/gea-support-search-content?contentId=16195 and http://www.appliance411.com/service/date-code.php . The first site lists how GE adds the date code in the serial number. The second site will give you the manufacture date after you fill in all of the details.
I hope this helps.
(Some code lists indicate that the 362 prefix indicates a Roper appliance built with GE parts.)
Apr 07, 2017 | Kitchen Ranges
What is the age of my GE TDX 9 SNY AWN
I need the serial number off the refrigerator. GE date codes the serial number from the factory. I will be able to tell you month and year it was built from the serial number.
Jan 20, 2016 | GE Refrigerators
I need help i have a GE universal remote RC430A Date code1636 I need to program the remote to the tv but i don't have the code. Please help.
Look inside the battery compartment and check the label. There may be a version code listed on that label. The GE remotes were manufactured by Jasco and the code lists are here: http://jascoproducts.com/support/ge-universal-remote-codes . Use the correct code list for the version for your remote. Note: these codes work for remotes sold in 2006 and later. For older GE remotes that use a 3-digit code, try this site: http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php .
I hope this helps.
(the remote control codes will often be limited to TVs that were sold at least 6 months before the remote was programmed. If your TV is newer than the remote, you may need to update your universal remote.)
Jul 10, 2015 | GE Televison & Video
Keep getting a f9 and f10 code . how do we fix what do they mean
1) F9 and F10 appear to be element failure/ Call for service
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#element
2) Copy following link for more GE Hybrid Geospring resources:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
3) Call GE and they will tell you to call for service:
1-888-443-4394
4) 2009 service manual says you can clear fault codes by pressing Filter, Lock, Vacation button sequentially within 3 seconds. Scroll to clear all fault codes using arrow keys. When that is highlighted, press Filter, Lock, Vacation again.
Others report this does not work, so it may depend on model. Or maybe buttons need to be pressed simultaneously.
5) GE does not want folks working on their own water heater.
Do not buy expensive water heaters you cannot fix yourself.
Average service call for GE heat pump is $400 which helps defeat anticipated savings from buying hybrid.
Jan 26, 2013 | General Electric GE GeoSpring Hybrid Water...
16 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
