Question about Boston Acoustics TVee Model Two TV Speakers
Resistor Identification or circuit diagram for wireless subwoofer
I was having an issue of the subwoofer cutting out occasionally, until recently when it just altogether stopped working. I took it apart and noticed that there are two burned resistors. My problem is, I am unable to identify the resistors due to discoloration. There are no other resistors that look similar to use as reference nor have I been able to find the PC board circuit diagram online. I am hoping someone has one of these units and can look on theirs and tell me what the value of the resistors are for R08 and R09. Any help is GREATLY appreciated. Thanks in advance.
  • Medina Valencia
    Medina Valencia Nov 27, 2013
    Here is a photo of the board with the resistors removed. If you own this sub, you just have to remove the screws from the square control panel and pull the panel out and locate the resistors. If you can just tell me the band colors and the order, that might be enough for me to work with. Many Thanks!
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same problem with my Boston acoustics subwoofer. have you find resolution for this problem?
Posted on Feb 22, 2018
How to fix 98 dodge caravan electrical / battery problems
Alternator voltage may be to hight that make the battery to dry out,or maximum output amp not ok and battery cant be fully charge
May 04, 2014 | 1998 Dodge Caravan
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
Two 10" Rockford Fosgate P1 subwoofers stopped making sound
Sounds like you've blown them.
When you were playing back to the friend, were you playing louder than usual?
Was the old box ported, and the new one sealed? The lack of ventilation may have caused the blow...
Jan 12, 2010 | JBL GT150 Car Subwoofer
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Left positive speaker input stopped working
try swapping over the rcas for instance if black is in r and red is in l then swap them so red is r and black is l
if that doesnt work try swapping the subs over to as you may have a faulty sub. if that doesnt work then check the fuses on the amp
still no joy then i would suggest taking your amp to your local car audio dealer and getting them to have a look at it
Hope this helps if so please dont forget to rate
best wishes
Upfront Audio
Apr 23, 2009 | Rockford Fosgate Punch® 450.2 Car Audio...
Radio/Clock stopped working but comes back on when I hit a bump
I suspect the problem is with one of the radio circuit boards, but check the connector at the bqack of the radio first, if that is clean and tight then the radio will need to be sent out for repair.
Sep 27, 2008 | 2002 Honda Civic
JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Apr 16, 2008 | JVC SP-PW100 Subwoofer
Intermittent Subwoofer
the wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Jan 13, 2008 | Kicker CVR12 Car Subwoofer
Unit will not charge
Call tech support at 866-486-6866. If you bought this unit within the last year, something will be done. In the mean time you can charge the unit via the USB cable, it will pull power from there.
Nov 21, 2007 | Tomtom ONE GPS Receiver
Boston Acoustics TVee Model Two TV Speakers Logo
141 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
