Question about Shure Audio Players & Recorders
No signal LX88-II is a dual wireless mic, one channel dosn't work anymore. Don't know if the transmitter or the reciever has the problem.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
See the following for repiars:
http://shure.custhelp.com/app/answers/detail/a_id/4053
Posted on Jul 27, 2014
3 Suggested Answers
SOURCE:
  • 611 Answers
SOURCE: how to change frequency of shure lx88 II station?
It is not user changeable. Contact Delta Audio at 773-764-3634. They have the parts and test equipment needed to perform this modification.
Posted on May 11, 2010
  • 611 Answers
SOURCE: transmitter of my mic does not satnsd at one channel
It sounds like the button is probably sticking. I suggest sending it to Shure fore repairs. Info can be found at www.shure.com/service
Posted on Jul 19, 2010
I have 2AKG UHFHT40ULTRA HIGH FREQUENCY handheld transmitter microphone , why when I turn them on they blink on and then notning ?
Okay, before going any further, let's just check....
  1. Along with your wireless mics, you have an AKG wireless receivers (e.g. WMS40 mini2), right?
  2. You've checked that mics and the receiver all work on the same frequency?
  3. You have connected both outputs from the WMS40 mini2 to individual mic channels on a mixing console?
Let's recap....
  • The AKG mics aren't going to work unless you have one of the matching receivers
  • The receiver has to be the correct type. This means if you want to run two mics at the same time, then you need a dual channel receiver (WMS40 mini2) otherwise they'll block each other. So, if you only have a single channel receiver (WMS40 mini) then you can only run one mic at a time, not two.
  • The mics and receiver have to be on the same frequency. They make it easy by colour coding the hand mics and the receiver. If the colours are different then they're working on different frequencies that are not compatible.
If you're good to go on all the above then the next stage is just the connection and set-up of the mics, receiver and mixer.
Since the mics are a pretty straightforward On/Off switch affair then there's not much to say there. Just make sure you maintain the correct distance for to ensure the wireless signal spreads out properly. It needs a minimum of 3m (about 10ft) distance between the mic and the receiver.
The receiver is straightforward too. It needs power, so make sure you plug in the mains adapter. The front LEDs give you the status of the signal. There's only two lights per channel, so it's easy to understand. RF OK confirms that the receiver is picking up the mic signal, so this one should be lit. AF CLIP let's you know when there's too much level from the singer/speaker. This could be that the receiver's volume control is set too high, or the singer/speaker is holding the mic too close for the volume they're producing.
The receiver's volume control needs to be adjusted fully counter clock-wise if connecting to a mixer by a balanced audio connection. If you're running in to the line level input, then the dial needs to be turned fully clock-wise.
The signal connection going to the desk should really be made with balanced leads. Jack to jack (TRS) or jack to 3 pin XLR will both maintain the noise suppression benefits of the balanced audio connection.
The rest is how you set up the mixer for the signal. Good luck.
Sep 14, 2014 | Audio Players & Recorders
I have a shure pg58 ut2 transmitter and pg4 reciever .. What channel should i set the reciever inorder to make the system work?
How if the mic is working but DOES'NT connect from the reciever because the red light is not working
May 09, 2013 | Audio Players & Recorders
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Sep 07, 2012 | DIGITECH VOCALIST LIVE 2
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Dec 29, 2009 | Philips LX3950W System
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
All 4 mics wil transmitt through channel a,
Sounds like all of your mics are using the same frequency. What you can do is change crystals in each unit to change frequencies, this will allow each mic to use its own receiver.
Mar 31, 2009 | Pyle Music
99 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
