Question about Panasonic SC-AK18 CD Shelf System
Semiconductor ic 501 - Panasonic SC-AK18 CD Shelf System
IC is wrecked
When you indicate the Integrated Circuit is 'wrecked', and you indicate due to lightning, I can only assume you are talking about the Power MOSFET's, in the DC - DC circuit on the motherboard......
Example using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Going further using the example.......
The Power MOSFET's used is the Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and the Alpha & Omega Semiconductor LTD - AO4407 - Power MOSFET.
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Here we see the FDS6679 is Obsolete.
Using the cross-reference example shown, for availability and price,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
Scroll down.
$1.01 USD (One Dollar and one Penny)
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
Obsolete also. Using one of the cross-reference examples given,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
78 Cents - USD
http://www.youtube.com/watch?v=3NN7UGWYmBY
Regards,
joecoolvette
May 12, 2013 | Packard Bell Computers & Internet
Sa-ht545 error code f61- comes up upon statrting
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Jul 09, 2008 | Panasonic Audio Players & Recorders
My stereo C918X turns off every time iput the volume up displaying f61
The audio output ic is getting to hot due to bad connections or ic failure. Check the speaker wires for shorts, if okay! semiconductor needs to be replaced.
Apr 10, 2012 | Panasonic SC-AK18 CD Shelf System
Picture looks like it is in 3D..What would cause this?
Convergence ICs are smoked. Needs dis-assembly, replace ICs, maybe fuses, usually minor adjustment.
The Red Blue and green images do not "converge" or line up. Caused by heat, power line bumps, lightning, collisions with vacuum cleaner, etc. Small amount of damage happens with each occurrence. Eventually semiconductor material at junctions inside STK IC is depleted and will not handle normal current.
In Canada, Call me.
Mar 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Light come on but not getting any sound.
First check out that the power supply has knocked down the voltage to the smaller levels that semiconductors work with say 12 to 25 volts. Look carefully at the main semiconductor. Check that it's got a voltage of this size going to it. If it is an IC, one pin should have it! If the power is working it's way to the main parts. Then I would think about replacing that main semiconductor. If it is an IC whip it out anyway.
Feb 17, 2010 | Sony SA-W305 Subwoofer
IC with number missing
use a bigger gage power wire
Aug 08, 2009 | Car Audio & Video
AdcomGTP500ii Bad IC cross-reference
Contact ADCOM thru their website
Theyre very helpful
Jul 26, 2009 | Adcom GTP602 2-Channel Amplifier
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
VS-50605 (mitsubishi) techman please read
Possible IC301, NOT possible IC501. Consult schematic diagram.
Oct 12, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Panasonic SC-AK18 CD Shelf System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
