Question about iClick Stealth Cam WD2IR Digital Camera
Black pictures my camera takes awesome pics during the day, though takes only black images at night. What can I do to make this right?
WHITE PICTURES AT NIGHT
Seems to me you are in stop action mode where camera takes one picture every x minutes. I need your settings to give better verdict. Fred
Nov 09, 2013 | Video Cameras
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
I took pictures at night, on auto mode. The next day I was going to take more pics during the day, still on auto mode. All my pics are almost completely white like the flash washed them out and if you...
Hi. Turn on the camera and go into the menu and find the reset function. Reset it. That may solve your problem. If it does not, you could go for a repair or a replacement. Some shops will give you a free estimate. Joe
4 thumbs up please. ty
Oct 21, 2010 | Samsung Digimax D53 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Memory Card claims ''no image'' and LCD black and wont take pics
first reformat memory card to FAT file system with computer, then reformat it with camera. this usually is the solution
Aug 10, 2009 | Canon PowerShot A590 IS Digital Camera
The pictures come out white...
Unfortunately your CCD chip has failed. Ifyou want to repair it, then you would need a new one.
Fujitsu is not selling them,and never have been.
A common fault with this camera (certain serial numbers)
germander
Mar 01, 2009 | Fuji FinePix S5000 Digital Camera
Pictures are red during the day.
U might need to change the mode in which u are taking the pics. Try setting it to Auto mode.
Mar 18, 2008 | Samsung Digimax D53 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
WHEN TAKING PICTURES OF MOVING OBJECTS THE IMAGES ARE VERY BLURRY, ALSO SOMETIMES WHEN WE TAKE A PICTURE THE WHOLE PIC IS BLACK ANY HELP?
WHEN TAKING MOVING PICTURES YOU SHOULD BE ON THE RIGHT SCENE MODE. AS FOR BLANK PICTURES WE HAVE FOUND THAT GENERIC SD CARDS CAN CAUSE THIS.
Nov 23, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
iClick Stealth Cam WD2IR Digital Camera Logo
15 people viewed this question
Top iClick Cameras Experts
Steve
Are you an iClick Camera Expert? Answer questions, earn points and help others
