Question about Drive Medical Hawk Three Wheel Scooter Cranberry
Drive gears - Drive Medical Hawk Three Wheel Scooter Cranberry
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
Http://www.monsterscooterparts.com/drivehawk.html
get in contact with these people they should be able to help.
Posted on Dec 05, 2013
1988 Dodge Ram 50 Automatic shifts into park reverse and neutral. But physically won't go into drive gears.
Disconnect shift cable from transmission linkage and try to manually put transmission in drive gear ( make sure wheels chocked/park brake on ). If transmission goes into drive gear, suspect a shift cable or shifter assembly problem. If you can't manually shift into drive gear by hand with cable disconnected, suspect internal transmission/shift linkage issue
Mar 10, 2016 | Dodge Cars & Trucks
Why the gearbox can easily change the drive gear?why the 5th gear stop to drive?
first pull the fill plug and check the oil level if low add some if not then it's a bigger problem and you need to take it in.
May 09, 2014 | 1988 Toyota Land Cruiser
Toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
May 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Transmission goes into nuetral when overdrive is ingaged
over drive is a gear its self it may be going out in the trany so when that over drive button it pushed it thorws it in to that gear that may be out no and it dont matter is you try to sift because it is a gear its self my car is 4 speed drive 1 drive 2 drive (3 gear) and overdrive (4th gear)
Mar 07, 2013 | Cars & Trucks
What is the second drive gear for
The first one is over drive and the second is drive. It is best to just use overdrive when on the parkway and drive on slower back roads when there is hills and stop and go traffic. Overdrive is a higher gear.
Dec 09, 2011 | 1998 Ford Taurus
There are 3 drive gears on my 2003 mercury sable what one should i drive whith
Got to be kidding
You use any and all vehicles in D or Drive,D4,D5
or what ever is the highest gear on the gear shifter
There never has been a reason to use any other
gear, unless you want to over rev & ruin the engine
There are not three gear drives, that are for you to use
Aug 08, 2011 | Mercury Sable Cars & Trucks
I just want to know the best drive to drive my 2007 Envoy in snow & ice on hills. My gears are 2up, Auto, 4up & 4dn. I drive in 2up, but today in the snow I put it in Auto, It drove pretty well. ...
The basic explanation of these gears are as follows.
2up/2wd is a basic two wheel drive setting where the vehicle will react as a rear wheel drive. In this gear the transmission will only distribute power to the two rear wheels(best for all around driving with clear road conditions and will give the best fuel efficiency).
4up/4wd is a high speed four wheel drive setting. in this gear the transmission will always distribute power to all four wheels and will allow you to drive at higher rates of speed( good for poor road conditions when ice and wet roads are a moderate risk).
4dwn/4lo is a low gear four wheel drive setting where again the transmission will distribute power to all four wheels but will limit you to a low rate of speed(good for really rough roads and severe weather or very poor traction conditions).
auto gear selection is basically a all wheel drive setting, where the transmission will use a primary setting of rear wheel drive gearing until the vehicle slips or looses traction on one of the drive traction. as soon as the transmission detects a difference in wheel speed between the two rear wheels, at which time the transmission locks up the front differential turning itself into a four wheel drive, until the wheels have regained traction and remain spinning at the same speed for a set amount of time, at which time it will then unlock the front differential at return to a rear wheel drive setting. this is a good all around gear but will cause you to get slightly less mpg/kpg then a 2up/2wd gear would. i hope this helps
Jan 09, 2011 | GMC Envoy Cars & Trucks
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
May 26, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Drive Medical Hawk Three Wheel Scooter Cranberry Logo
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
