Question about Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX
How does a dreammaker hot tub heat the water - Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX
  • Jandy Master
  • 1,631 Answers
Some have a electric heat element, while some others have a "Exchanger" system utilizing the heat from the pumps motor to transfer that heat to the water. Pump will be on a lot!
Posted on Jan 29, 2014
DreamMaker 8003-xcal B6L Hot tub jets will not turn off, seems like they're always on? Why is this, and how can I fix?
When you say the jets are always on..do you mean on high or are they sometimes just very low flow?
If it is a very low flow it could be that you are seeing the jets when the spa is heating and/or filtering.
US Parts Center
Sep 01, 2013 | Home
Dreammaker
if voltage to unit check fuses then heating element and pumps
Aug 01, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
I have a leak in my Dreamaker Eclipse hot tub. Within a few days, the water level drops to the bottom of the lower water jets then stops. We didn't use the tub last winter but I completely drained it...
Thats the problem with Dreammaker tubs, access can be a pain and theres no easy way of getting to the pipes.
I would usually gain acces from the underside which ensures that any holes that need to be made to gain access wont be visible in the future.
Good luck locating the leak.
Kind Regards,
Ian.
http://hottub.synthasite.com
Jun 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Over heating
Try turning the power off and back on again.
If this doesn't solve the problem you have further issues.
Regards,
Ian.
Feb 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX Logo
109 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
