Question about Dynex Cross-cut Shredder
Nead gear replacement
Need gear replacement part
  • 189 Answers
The large electronic store chain Best Buy owns the Dynex Product Company. Having dealt with other Dynex products in the past, you will probably end up having to throw it away and buy a replacement.
Posted on Dec 10, 2013
NEAD A NEW ENGINE
need to bring car to head shop to have them work and re done car don't need new engine
Aug 08, 2012 | 1998 Chevrolet Monte Carlo
Leak when in use I need to remove caseing
on the back of the control panal you nead to remove the two screws one on each side,next you nead to pull the panal forward and flip it up.unplug the door switch,next remove the two s-clips that hold the body on.pull the body forward and remove the body.next look down and you will see the water pump.if there is water under the pump than you have a bad seal in the water pump.you nead to replace the pump.you may nead a pan to catch the water that is still in the washer when you remove the hoses from the water pump.remove the two clips from the water pump and replace the pump.
Jan 19, 2010 | Whirlpool LSB6200KQ Top Load Washer
I need help replacing my switch lid on my Kenmore 70 Series mod. # 110-22722100 Washer. Can anyone help me with this??
if you have a gray switch than you nead to bypass the switch.if you replace the switch it will brake again.you do not nead a door switch.
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Chain drive gear broke on my mod.1265LM. Nead price, part no., and how to replace? Thanks Dave
The drive gear part number is 41A2817 and the price for the kit is around $25.00. It comes with instructions.
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Whirlpool works in every way but will not spin.
sounds like a bad door switch,to replace the door switch you will nead to remove the body.first you nead to remove the two screws behind the control panal one on each side.next pull the panal forward and flip it up.next you nead to unhook the door switch.next you nead to remove the two s-clips one on each side.next you nead to pull the body forward and remove the body.now you con remove the two screws that holds the door switch on under the door next remove the door switch connecter from the body and install the new one.next reasemble unit
Dec 18, 2009 | Whirlpool LSB6200KQ Top Load Washer
My Roper dryer won't start?
first make sure you 220 going to you dryer.next you nead to unplug the dryer.next you nead to remove the vent hose.next you nead to remove the back panal and power cord cover.on tge lower left side you will see a white plastic switch with two blue wires going to it.this is the thermal switch.if you use a meter and the switch is open tha you nead to replace this switch.part#3392519
Nov 11, 2009 | Roper REX4634KQ Electric Dryer
Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
How to adjust parking brake 05 impala.
u will nead to get under the car. how u go about that is up to u but do it safe an have mate around. go to your front door this is the best place easy to reach your hand brack hear. look where the gear stick is up front u nead to be under the car where the gear stick is find it then look a bit downback from gear stick an u will see it. when u do the hand brake up do not hav it on u wont to have max 8 click,s an u,ll be fine. hope this helps u
May 28, 2009 | 2005 Chevrolet Impala
Dynex Cross-cut Shredder Logo
166 people viewed this question
Top Dynex Office Equipment & Supplies Experts
graybeard32301
ray gallant
tony wahlman
tony wahlman
Are you a Dynex Office Equipment and Supply Expert? Answer questions, earn points and help others
