Question about Black & Decker Distance Measurer with Sensor, Marksman
How to use stud finder - Black & Decker Distance Measurer with Sensor, Marksman
  • 2,113 Answers
While holding the stud finder on a spot on the wall where you assume there is no stud... press the button and hold and stay still for 10 or 15 seconds to calibrate. Then while still pressing the button start sliding sideways until the lights indicate the thickest point. You can use a pencil to mark the beginning and end. The center of that is the center of the stud. Measure 3/4 of an inch left and right of it to know it's sides.
Posted on Nov 24, 2013
  • mikadot
    mikadot Nov 24, 2013
    It also locates metal in the wall ie: pipes and electrical boxes, wires
  • mikadot
    PVC, ABS plastic tubing too
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
Battery change on a stud finder
I need to know the brand/model#. My stud finder has a release tab on the underside and it's easy access. Can you snap a picture and repost?
Nov 21, 2013 | Vacuums
Instruction for Stanley FatMax Stud Sensor Finder 400 (77-730)
Please people dont waste your money but a cheap standard one Stanley 77-730 stud finder is bad does not work at all , miss my old cheapy never failed me
Mar 05, 2012 | Stanley Measuring Tools & Sensors
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
How to use it
usually you put it up against the wall between studs. Then you press a button and gradually move it left or right to find the studs in the wall.
If you initially have it pressed against the wall at a stud, it won't work right.
Jul 10, 2010 | Ryobi WallTech Stud Finder Stud Finders
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
Lost instructions to Ryobi EMTP006 stud finder, I don't remember how to use.
1st press and hold the yellow button on the side until " on " is displayed. THEN after 3 seconds unit calbrated and ready to scan. bar graph and audio indicates edge.
sonic tape
just press read and it will read up to 50ft
"x" button gives area and volume
" " for addiction of length
Jul 13, 2009 | Ryobi WallTech Stud Finder Stud Finders
Black & Decker Distance Measurer with Sensor, Marksman Logo
357 people viewed this question
Top Black & Decker Measuring Tools & Sensors Experts
Vuk B
Dennis
frankrome
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
