Question about Video Game Consoles & Games
Mike fairclough - Video Game Consoles & Games
Did the small faces appear in a movie in the 1960s
Yes it was DATELINE DIAMONDS (1965): Lester Benson manages one of the biggest rock bands in 1960s Britain, the Small Faces (as themselves). He happens to be an ex-con who wants to return to the crime scene. He summons the help of Major Fairclough who safe-cracks diamonds to smuggle into the Netherlands via the Big L's ship. It seems a perfect crime as no-one served as a witness, except for an intellectually-challenged bus conductress called Mrs. Edgecomb who saw Major Fairclough ("a military-looking man"). Written by Reece Lloyd
May 31, 2015 | Audio Players & Recorders
I have installed new HP cartridges (black and colour)but on testing I get no colours except magenta violet and red!! Peter Fairclough
You must set to clean the print head. Yellow ink doesn't work. Try to clean the print head with some hot water, untill you'll see yellow ink came out. Time to time you must print some color files do not dry the ink.
Mar 31, 2011 | Office Equipment & Supplies
Mike problem
nokia mike problem cant be solved as it is a hardware problem
mike should be changed.....
go to the nearest service center and change ur mike my dear........
Jan 22, 2011 | Nokia 2600 Classic Cell Phone
I have a Fender Passport 150 and my microphone is won't work but everything else does......????? Thanx Mike
Mike try the microphone if possible on another set If the mike makes a noise check for frayed and bad cables. As far as I know the mike is a dynamic mike and connect it to the speaker of a small transistor radio and it should sound.like a small speaker for dynamic mikes and ordinary speakers work just the one as a generating device(Speaker) and the other as a sound pick up Look at small to way radio's the send is the speaker a mike and on receive it is a speaker, Hope this help
Nov 14, 2010 | Lectrosonics FENDER PASSPORT PD-150 + 1...
I've attached an external mike to the canon hv 30 but the audio levels are very low. I've tried increasing them as per the manual's instructions but still not as responsive as the shotgun mike. could it be...
what kind of mike are you plugging in?. Some cams will use crystal mikes...some use dynamic....some use a mike with a pre-amp built into the mike.(condenser mike) Also you must match or at least come close to the impedance required by the camera.The hv30 requires a condenser microphone. Check with radio shack or some electronic store.
Jul 07, 2009 | Canon VIXIA HV30 DV Camcorder
W300i speaker stopped working, other side cannot hear my voice
Hi, my w300i speaker (mike) stopped working, my voice cannot be heard on the other side, but, when I connect the handsfree, things become fine.
Seems, the internal mike has got a problem, please suggest a remedy?
is it mandatory to get the mike changed, something similar had happened a year back and that time, they had said, that since the mike is a part of the board, the entire circuit board needs to get replaced.
Any idea, how much the board (circuit) will cost in Mumbai, India?
Mar 25, 2009 | Sony Ericsson W300 Cellular Phone
Broken mike port
you can buy a mike thing in computer shops like pc world, its a stick with a mike thing thn plug into the bit were ou put usb wire intoo thn thts it dun:)
Jan 03, 2009 | Acer Aspire 5100 Notebook
Dvd drive
You shouldn't have to format each time.
It might be the software you are using...
I haven't had to do that since my first cd burner 8ish years ago.
Here is a link to other cd burning software
http://www.snapfiles.com/Freeware/gmm/fwcdburn.html
Dec 17, 2008 | Computers & Internet
Very old astatic 525 mike wiring
Hello..maybe not a solution..but a hint..measure red-black for 0 ohms while pushing "ptt button" i think it's ptt...bare and transparent is mike...but you can look at original mike and make the same measurement for finding out what is ptt..the two others is mike ...good luck...Ron
Mar 13, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Mike wont work
PRA-H7A is a super-cardioid back electret condenser microphone, therefore turn on the PHANTOM POWER before you try to use it again.
Nov 08, 2007 | Superlux PRA-H7A Professional Microphone
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
