I want multicast routing code in matlab - Computers & Internet
Does MA5800 support the Multicast?
Yes, it supports Layer 3 multicast networking, also supports IPv4 PIM SSM.
Protocol Independent Multicast-Source-Specific Multicast (PIM-SSM) enables a user host to rapidly join a multicast group if the user knows a multicast source address. PIM-SSM sets up a shortest path tree (SPT) from a multicast source to a multicast group, while PIM-SM uses rendezvous points (RPs) to set rendezvous point trees (RPTs). Therefore, PIM-SSM implements a more rapid join function than PIM-SM.
Different from the any-source multicast (ASM) model, the SSM model does not need to maintain an RP, construct an RPT, or register a multicast source.
The SSM model is based on PIM-SM and IGMPv3. The procedure for setting up a multicast forwarding tree on a PIM-SSM network is similar to the procedure for setting up an SPT on a PIM-SM network. The receiver's DR, which knows the multicast source address, sends Join messages directly to the source so that multicast data streams can be sent to the receiver's designated router (DR).
http://www.thunder-link.com/HUAWEI-MA5800-X7_p928.html
Jan 06, 2017 | Computers & Internet
What features does IP Lite bring to the WS-C2960XR-24TS-I?
IP Lite introduced enterprise access Layer 3 features to the Cisco WS-C2960XR-24TS-I. IP Lite is subset of IP Base features. Some of the IP Lite features are:
Routing Information Protocol (RIP) v1
Routing Information Protocol (RIP) v2
Open Shortest Path First (OSPF) v2 Routed Access
Open Shortest Path First (OSPF) v3 Routed Access
Enhanced Interior Gateway Routing Protocol (EIGRP) stub
Equal-cost routing
Hot Standby Router Protocol (HSRP)
Protocol Independent Multicast PIM (Sparse Mode, Dense Mode, Sparse Dense Mode, Source Specific Multicast) stub
Virtual Router Redundancy Protocol (VRRP) for IPv4
Private VLAN
IPv6 First Hop Security source guard
Per-VLAN and per-port policers
http://www.3anetwork.com/cisco-ws-c2960xr-24ts-i-price_p1874.html
Apr 17, 2015 | Cisco Computers & Internet
Matlab codes
Do you still need an answer with your "school-homework" ?
Aug 28, 2014 | Computers & Internet
Gradient projection
He re is the link to a Gradient Projection algorithm for factor analysis (in Matlab). You will have to see for yourself if its fits your needs. The code is Use without change.
http://www.stat.ucla.edu/research/gpa/matlab.net
Jan 10, 2014 | Computers & Internet
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
Sep 08, 2011 | 3Com Switch 5500G-EI (3C17261) Network...
How to convert a matlab code to c
Go to dir where ur matlab is installed through command prompt and type
\mcc -m filename
for example face.m type
c:\matlab7\bin\win32\mcc -m face
sure that matlab compilar should be installed into ur system if not than use help as command prompt says or install it.....if any other problem comes than mail me...pankaj.indoria@gmail.com
Nov 20, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
