Question about Proscan PS32500 32" TV
32 inch tv no sound
This is a hi def LCD TV and has no sound. Using the remote doesn't help. Can it be fixed?
  • 814 Answers
SOURCE: I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
Posted on May 21, 2009
  • 13 Answers
SOURCE: Hi, I just bougth a 32
ok so buy a remote control if you already have one and lost the book search it up on google,dogpile or the companys website
thanx i hope it worked
Posted on Sep 17, 2009
SOURCE: no signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Posted on Nov 12, 2009
SOURCE: Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Posted on Apr 28, 2010
  • 35687 Answers
SOURCE: What is the code to program an iview universal remote 2600 hd to a proscan 32 inch LCD TV model no. 32LB30Q
You can use code search to find something the handles some or all functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Posted on Mar 13, 2017
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Feb 18, 2009 | Emerson Televison & Video
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Channel keeps changing
If you are using the remote to change channels it sounds like either the front of the remote and/or the receiving “eye” on the TV need to be cleaned, OR (more likely) the button on the remote is sticking. It is actually a button that pushes on a membrane under the entire remote panel. This is generally caused by some sticky liquid (like Coke) getting spilled on it. If you are brave enough, you can take the remote apart and clean it with denatured alcohol. Otherwise you need to replace your remote. If possible borrow a universal remote and see if it still happens. If that doesn’t fix it you have a bad IR receiver and/or a serious internal problem.
Jan 29, 2008 | LG 32LX1D 32 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
Google Allelectronics or Hosfelt Electronics for these caps
I just ordered these at a good price but ordered 35Volt instead.
Also replacing 3300uF caps too as they are bulged at top.
Hope this fixes it. Will let you know.
Nov 14, 2007 | Astar LTV-3201 32 in. LCD Television
Proscan PS32500 32" TV Logo
20 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
