Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Cannot Print Manually
Hi, I found problem in copy and as well as in Manual Printing of Journal. Please could you give some suggestion regarding this.
  • Kenwoo Mar 18, 2009
    When ever i try to print a journal - Function 6, 1 Set, 1 (print journal), 2 (view journel), the fax machine beeps twice and does nothing. This happens for any manual print outs, and when I attempt to copy a dcoument. I can receive and send faxs... Any ideas????
    Problem Solver:
  • 13 Answers
Need more info
Posted on Oct 14, 2007
6ya staff
SOURCE:
How do I switch the journal feed off 4500 f
If you mean turn the journal printing off, you can't. It doesn't have a journal memory because it is designed to print everything on the journal roll. That is why you buy a two station printer model. It stops staff from covering transactions and the tax office will want to see your journal rolls if they audit you.
For those who asked about a programming manual for the Casio TE4500F, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
May 09, 2015 | Casio TE-4500F Electronic Management Cash...
Hi the receipt will not print out but the journal is fine, do you know i can fix it?
Have you checked to see if the paper is in the correct way round, most tills have a receipt turn off mode. Consult your manual to find out how to switch back on
Aug 02, 2014 | Casio Cash Register
How to stop journal printing on XE A404 Cash Register Printing
Go to system option and on Contineous Journal select 0
Feb 03, 2013 | Sharp XE-A404 Cash Register
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
Two sided printing or copying give eroor e000064
Hi
please fallow these
1.replace drum unit
2.go to Additionan option then press * and 2and 8 at a time and go to Function and copier and Developer increase the developer number after that you will be able to resolve this but the Quality of print/copy is not good.
Regards
Vithal
Oct 08, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I want to report all the telephone numbers dialed today. How wil
You can either view, or print the transaction reports. The machine should print out automatically after 32 transactions, or you can print manually. To print out manually after each transacton, from the control panel select "function", 6, 1, set key. Pesssing key 1 will print journal, pressing key 2 will let you view journal. To set the printing of transaction report for all sent faxes, you can get into the fax parameter setting #13, and scroll to your selection using the up (^), or down keys.
Dan
Jan 07, 2009 | Office Equipment & Supplies
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Journal receipt won't print.
Hi. The journal side should always print (right side of printer). There is no way to turn it off. If it is feeding the journal paper, but not printing, then you may have the roll in back to front (in the case of thermal printers). If it doesn't feed at all, then you may have a feed problem. In this case it will usually be printing over the same place on the roll continuously. Another thing to test is whether it prints on both rolls when printing Z reports.
If none of this helps, then please let me know the brand and model number, and I will try to suggest more checks.
Mark
Aug 30, 2008 | Casio Parts Cash Register PC Desktop
Printing error
Try to printing a configuration page from the print board if this works check all your network cables then try to PING the copier by...
Go to START on computer
then RUN
then type "cmd"
then type ping
press the space bar once
then the ip address in full and press return
if your network is ok you should get a signal return
and NOT a timed out message
If your network is ok
Try deleting the printer and re-loading the print driver making sure the IP address is the same as the one on the configuration page.
If you require more help please get back to me
Thank You
Mar 09, 2008 | Canon imageRUNNER 400S Copier
Receipts
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
Feb 12, 2008 | Epson TM-U220 Matrix Printer
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
