Defrost & power lights are blinking, Unit does not heat.
Manual says extreme cold temps may cause problems. 20s last night, 40s today. Tried emergency on/of, nothing. Turned unit on cool & fan came on. Outside unit hasn't come on at all.
    Genius:
  • 1,198 Answers
Heat pumps are only good above certain temps, like mentioned. Then usually heater coils come on if the unit has them. It may not. Check the manual, or Google the make and model for a user manual. Make sure all your breakers are on all the way, not tripped. A tripped one will be a little away from on, turn it all the way off and then on again.
Posted on Nov 24, 2013
Testimonial: "I have the manual, read all troubleshooting in it. This unit is a heat pump, not just AC. It was heating a few days ago, just stopped today after having 20s last night. It's not the breaker. Thanks anyway."
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
haystack11
  • 55 Answers
SOURCE: Rheem heat pump,have to keep pushing red reset button for fan
Either the fan motor is going out OR the compressor may need a boost of power from a quick start.
When the compressor gets old, sometimes it requires a little extra power to get it going.
Your unit should be under work warranty if they installed it.
Posted on Jan 06, 2010
  • 3 Answers
SOURCE: Electrolux Kelvinator - Unit on defrost
Check the defrosting sensor on the coil or the solanoid on the reversing valve.
Posted on Jun 07, 2010
Blinking Fridge Light and Both Fridge & Freezer Warming Up
I would say to contact Servall, a component source for all appliance repairs. They have a Web site and are helpful. You should also try the Web for any repair Manuals for your unit.
There are timers for the Defrost cycle. I am familiar with the old mechanical type, the blinking of the computer type is often in a Code which diagnoses the problem. You need the Manual to translate what the blinks mean.
Jul 10, 2014 | Samsung Refrigerators
Kenmore 13 (1989) model 253.9103221 has been unplugged and safely stored flat in an non-climatized shed for seven years. I plugged it in outside in the carport, night temps getting in the high 30s low 40s....
Moving it inside will most likely fix the problem. The thermostat is often located in the frige side, so it's basicly too cold outside for the unit to run right.
Oct 26, 2013 | Whirlpool Refrigerators
I moved my freezer to the shed 6 months ago as soon as the cold weather hits the freezer has stopped working. The light is on inside and out, defrost timer is working. I?m thinking thermostat or compressor
Freezers & Fridges were not designed to operate in extreme cold conditions. They are designed to operate at room temp. It could be sending an inaccurate temp signal to the thermostat due to extreme low temp outside.
Nov 27, 2010 | Refrigerators
I have a Magic Chef compact fridge. There was a lot of ice build up in the freezer compartment. I attempted to defrost it last night, but I also tried to break away the ice before it was completely...
either the defrost heater element or defrost thermostat is open behind the rear wall where all the ice buildup was and is bad or the defrost timer in the front area isn't working to defrost the unit on a 12 hour schedule,you will need to test each component
Oct 14, 2010 | Refrigerators
Whirlpool side by side made in 1998 is not cold. freezer side temp ranges between 32 - 40 degrees at coldest setting. coils are clean. blower is working. could thermostat be stuck or freon low? where do...
Most of the time there is an automatic defrosting problem when the freezer starts warming up. Ice builds up on the evporator coils.. airflow gets restricted and the temps warm up. Check to see that your evaporator fan is running at full speed. If it is then do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
If temps are normal you have an Automatic defrost problem.
Causes can be:
1. Defrost timer / control
2. Defrost Heating Element
3. Wiring
There are other causes but timer / control or the element in a 10 + year old unit are the normal failures.
Do this step before the manual defrost
Make sure that the condensor fan in the lower rear part of the unit is running at FULL speed.and that the condensor coils are free of lint and debris. If the condensor and fan are loaded with lint it will cause warmer operating temps. Clean as needed.
If after you do a manual defrost and the temps come back to normal for at least 24 hours you will need to troubleshoot the auto-defrost circuit. If you need help at that time just respond here and I will help you.
Thanks for Choosing FixYa
Kelly
Sep 18, 2010 | Whirlpool Refrigerators
Model TFX30PP purchased 9-10 years ago. The refrigerator & freezer are not cold enough. There was frost built up in the back of the freezer. We defrosted it. Plugged it back in - fridge read in the...
What you have is either a bad heater or heater bi-metal thermostat most likely. I say that since the ice box is working correctly until that frost builds up. Have you checked them. Your heater should test good for continuity(not open or bad) but the bi-metal is a different story. It is open at 50 degrees f and it only closes or carrys voltage when it is sitting in a freezer at 25f. What it does is allow power to the heater when the timer or automatic control calls for defrost. The defrost cycle is around 20 to 40 minutes and power is constantly being sent to that heater the whole time. When it gets warm enough for frost to melt 50F then that bi-metal opens up and kills the power to that heater. If that heater was to stay on it would not be purty. For the rest of the defrost cycle the coils simply rest and drip.
Jun 09, 2010 | Refrigerators
My outside heat unit is frozen and it is 10 degrees out, will it thaw while I have it on emergency heat? How long do I keep emergency heat on?
Switching to emergency heat will not defrost the unit.
If the Heat pump is malfunctioning, continue to use the emergency heat until the unit can be repaired properly.
At ten degrees, no heat pump can keep up., but it should be automatically bringing on the heat strips as back up heat. (same thing as emergency heat, it's just automatic.)
Either the extreme cold is overloading the defrost system, due to lack of properly operating exterior temp sensors or the defrost is malfunctioning,
Feb 07, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Pentair MasterTemp 400 Heater Will Not Fire
Long story but bingo just at the end. The thermistor is generaly the problem with what you describe. it is an inexpensive part and easy to replace. You will not generaly find this in your book. Your E5 code is just because the unit hasn't started yet. Good luck.
Jan 25, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
WINDOW AIR CONDITIONER SHUT ITSELF OFF
Some units have a dehumidify setting to overcome this as they go through a defrost. You can either manually defrost running on heating for a few minutes, or have it defrost when it goes out on fault as happened.
Jun 19, 2009 | Heating & Cooling
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
