Question about DeLonghi Coffee Makers & Espresso Machines
Coffee espresso machine is delivering too much water when requesting a single or double coffee. the expesso requests seem to be okay.
    Habit-Forming:
    New Friend:
  • DeLonghi Expert
  • 123 Answers
Press the coffee button and hold it until it prepared the coffee.When decide that enough amount of coffee in the cup, run button and the machine will store the new length.
Posted on Nov 28, 2013
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
  • 5 Answers
SOURCE: whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Posted on Jan 18, 2010
Too much water in coffee
coffee is too large, decrease larger than the button inside the beans.Turn it to a smaller number.
Nov 24, 2013 | DeLonghi Coffee Makers & Espresso Machines
How to troubleshooting water blinkint light problem of ice cube scotman machine
This machine is requesting to be cleaned with ice machine cleaning solution you can purchase @ home depot, or just plain old viniger and water.
Jan 25, 2012 | Saeco Incanto Classic Espresso Machine
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
It grinds the beans, but just a trace amount of coffee is brewed and drips out.
My F9 started with the "Fill Beans" routine even though there were plenty. The grinder started making a high-pitched noise, which Capresso's customer service told me was indicative of something being stuck in the grinder (like the stones mentioned in the manual).
Their suggestions ranged from vacuuming out the grinder to blowing compressed air into it, to "burping" the machine -- which they describe as hitting it mildly while grinding. Kind of a Heimlich maneuver on the thing.
Still no success, but I did turn the unit upside down a few times and shook out a *lot* of coffee grounds. This led me to believe that the grinder was still working, but something was blocking it down low. So I ran the cleaning cycle twice, and voila, coffee again.
An interesting aside was that the first dump from the first cleaning delivered the usual grounds but also some more pasty-like remains, and pretty dirty water. The dump water from the second cycle was very clear. This is a testimonial to the efficacy of the cleaning process. If you don't do this when the machine requests it, you are running the risk of gumming it up. I know (now); I had been ignoring the request to clean it for about a week and a half...
Dec 26, 2009 | Jura Capresso Impressa F9 Espresso Machine
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
I get the same amount of water through the espresso side whether I choose 1 cup or 2 cups. So if I use the one cup espresso holder & that much espresso it is watered down.
In a properly working machine you should get about 50 ml (1.5 ounces) for the single and about 100 ml for the double. The amount is also programmable and just about the only way to get the same amount is to program both to deliver the same amount. The unit has a flow meter to accurately measure the amount of water going to the espresso. Try the program function to reset the amount for single and double.
Oct 14, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
