Mitsubishi mr slim troubleshooting
Power & defrost lights blinking, won't heat
    Master:
  • 613 Answers
The defrost relay contacts are most likely welded shut and needs to be replaced. Call a tech.
Posted on Dec 08, 2013
  • 6 Answers
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
22yooper
  • 828 Answers
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Posted on May 22, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
manhandy
  • 146 Answers
SOURCE: Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Posted on Jul 18, 2009
Rheem heat pump not coming on in heat mode. Control board has two LED lights # 1 solid, #2 blinking. What does this mean?
Usually wen the led lights are blinking it means there is a problem. If you look on the door or the cover there should be a code that tells you what the blinking represents.
Example - one blink per second - compressor, two blinks - fan motor, etc. The other thing you can do is look up the model number on line for the installation manual and it should have all the info you need.
Jan 08, 2015 | Ruud Defrost Control Board 47-102684-08...
Blinking orange light
The blinking light is a symptom of power suppply trouble in this type of tv
Apr 21, 2013 | Dell W2600 26 in. LCD Television
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
