Question about AT&T Samsung a117 Pay-As-You-Go Cell Phone - Black
At&t overcharges on go phone minute usage
Go phone standard model at&t regularly overcharges minute usage to about 25 cents a call ...
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
My charge got broke can i use a regular usb charger
Press "Volume +" together with "Power on", during 8-10 seconds. Choose first line in menu.
Feb 08, 2014 | RCA Ipod Tabletop Charger With Usb Port...
Since a new meter was fitted my lights keep tripping
1) Understand electric service:
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) Do a heat test on breakers and outlets and switches, than a stress test on main breaker box.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
3) Check that wire size and breaker size match
http://waterheatertimer.org/Color-codewire.html
4) Break new meter with hammer and they will replace with another new meter made in China, intended to put local workers out of a job, so we can pay for automated meter reading requiring software owned by foreign investors charging at least 25 cents per month per customer to read the meter, using workers located somewhere else, which doesn't include cost of necessary towers and maintenance, or include software upgrades, or include needed security upgrades. Oh, but you will be able to pay additional monthly fee to get static snapshots of power usage at 15 minute intervals, and the switch controlling your power will be located somewhere besides your town.
Dec 02, 2012 | Electrical Supplies
Toshiba satellite A135 At the power on disk read error comes on & says press ctrl+alt+del to restart, but after restarting, the same reading comes on!
Disk read error is, most likely, a bad hard drive. Seeing this message means that the operating system (Windows) didn't even get a chance to load before running aground. This model uses 2.5" SATA drives and 80G is the smallest size ever sold. You can probably get a replacement drive (new or used) locally or thru eBay or Amazon, and they should be pretty cheap (new ones should run for about 20 cents to 25 cents per gig. That'd be your best bet.
Aug 31, 2011 | Toshiba Satellite A135-S2276 Notebook
My daughter's phone is draining money at the rate of 19 euro cents every 20 minutes. The internet option is not on and there are no texts being made. Could this be a virus? software version: KP500AT_V10d
The best thing to do is to ring the phone supplier..i.e t mobile, orange and ask if they have a explanation for this.
They will have record of phone calls,texts,internet use etc as they need to bill you.V strange situation but ring and tell!
Hope i`ve been of help.
Nov 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Change network
it's easy - go to www.vodafone.com.au/unlock & follow the link to do it online. It mentions charging $25 to get it done, but I entered my phone's IMEI (explained in their instructions) - it instantly gave me the unlock code without charging a cent. I guess that's because it was out of its contract, but that's pretty cool compared to other mobile companies. (I did this yesterday: 4/6/09.) Good luck.
May 02, 2009 | Nokia e65 Cellular Phone
Alltel Bill question
On Alltel U prepaid, you get two free features for 75 cents a day, three for $1.00 a day, and four for $1.25 a day.
The four features offered are unlimited text messaging, unlimited night and weekends (N&W), unlimited mobile to mobile (M2M), and unlimited calls any one number. You decide which ones you want.
The fee is charged every day, regardless of usage or not.
The only way to not get charged every day is to switch to the pay-per-minute plan or get a monthly plan.
Dec 10, 2008 | Samsung Hue (SCH-r500) Cellular Phone
When i click on someones nick & the page comes up it will freeze up & i cant type a message & i get a error message from microsoft it does this every time after i sign in
It sounds to me like your messenger software has been corrupted somehow. To fix this simply go into add/remove programs and remove the messenger software from you computer. Go to the MSN site and download the latest version of the messenger software and install it. This will resolve you problem for you. It is a good Idea to check for newer versions of you software regularly because the updated versions have all the bugs resolved like the one that you ran into and also they are adding cool new features with every update also. Many of the messengers are offering phone out now where you can call anywhere in the world for 1 to 2.1 cents a minute and computer to computer voice calls for free. This is what I use to call my customers world wide. Yahoo voice out is the cheapest and the best voice quality. For 29 dollars a year you get your own phone number for your computer and out going calls are only a penny a minute long distance and 1.9 cents a minute international and PC to PC are FREE. 800 numbers are free too. It sounds like the people are in the room with you.
I hope you find this info helpful and it fixes your computer too. feel free to contact me if you need more help with this or anything and I will help you for free. Make sure you come back and rate me when you get your computer going. If you need more help you can get to me at geokohler@gmail.com. I check my e-mail regularly. Just let me know and I will get right back to you.
George
Aug 05, 2008 | Computers & Internet
AT&T Samsung a117 Pay-As-You-Go Cell Phone - Black Logo
14 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
