Question about Vehicle Parts & Accessories
The truck starts briefly then shuts off and continually tries to start and the same thing keeps happening. 2007 Toyota 4 runner
emissionwiz
  • 78326 Answers
SOURCE: how to change transmission fluid on a 91 Toyota 4
This is a really messy job, but here is what u must do, jack the truck off the ground and secure with safety stands, there is a sheet metal pan on the bottom of the transmission, remove it, fluid will go everywhere, do u have a large drain pan? measure the fluid drained out and put the same amount back in, the run the engine until the trans fluid is hot at least 180 deg Fahrenheit, recheck the trans fluid level and top off, donot overfill!! u can destroy the trans if u do.
Posted on Mar 24, 2009
steve_baldam
  • 52 Answers
SOURCE: '96 Toyota 4-Runner makes a loud squealing noise and brake light
Sounds like one of the auxillary belts slipping it may just need tightening up. I think the 4-Runner has two belts one large and one for the steering pump
Posted on May 13, 2009
pippall
  • 1486 Answers
SOURCE: 1991 Toyota 4 Runner - Not Getting Fuel
change the fuel pump.
Posted on May 29, 2009
  • 27 Answers
SOURCE: 2007 Toyota 4 runner transmission filter and fluid change??
at 50,000 miles there is really no need. i would wait and save up that money and do a transmission flush 7- 10 quarts of toyota f-type fluid can be costly but a flush removes all of the fluid and garnish along with any fine shavings (normal wear and tear) out of the tranny and replaces it with new clean fluid. normal intervals would be at about 80-100,000 miles. you should be able to find preventative maintenance schedules in your owners manual. if not any repair facility would have it on their computer.
Posted on May 30, 2009
luckyluke78
  • 333 Answers
SOURCE: 1995 toyota 4 runner starting problem once in awhile
Is the starter turning over the engine when it wont start or is nothing happening at all?
I might have your solution if I have more details.
If the engine is turning over but not starting then switch on the ignition and push it to start.If it starts you probably need a new ignition switch.
Please get back to me .Thanks
Posted on Aug 05, 2009
Changed air filter in 1995 toyota 4 runner and after putting air box back together the 4 runner won't start
does the vehicle crank? if it does please remove the old air filter and leave the air filter intake box open, unplg the maf sensor, try and let me know.
saif
Apr 01, 2014 | 1995 Toyota 4Runner
Whining in rear end 2007 toyota 4 runner
check your sliders holding the pads .take off ,and clean and grease them
Dec 26, 2013 | Toyota 4Runner Cars & Trucks
When do spark plugs need to be changed on a 2007 toyota 4 runner?
Nowadays, I've seen spark plugs last 100,000 miles. The center electrode in a spark plug will wear down, causing a wider gap between the center electrode and side electrode. This wider gap causes harder starts, and if wear is too excessive, it will cause a no start. Hope this helps, Gary
Jul 28, 2010 | 2007 Toyota 4Runner
Car won't start
Try to keep bumping the key like you were trying to start it and hold it till it starts if you hear it start to turn. Its most likey the starter
May 03, 2010 | 2007 Toyota Camry
1999 Toyota 4-Runner sometimes won't start
Sounds like the starter is getting ready to go out. I'd look at being ready to replace it soon. If it is a stick shift transmission car, you can PUSH start the car, but you probably want to get it done before this happens. This is what mine did, click, click, start, over a period of about 2 weeks before it finally went out. Replaced it, starts first time every time now.
Hope this helps.
Mar 20, 2010 | Toyota 4Runner Cars & Trucks
Car alarm activates when trying to jump start
look under the dash on the driver side look for button, (valet switch) press button and then crank.
Aug 24, 2009 | 1990 Toyota Cressida
My daughter's 1987 4 runner won't start after driving some.
bad fan relay.see if your radeater has good flow. if you keep running it like that you will lose your motor
Apr 05, 2009 | 1987 Toyota 4Runner
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
