Question about DeLonghi Coffee Makers & Espresso Machines
Too much water in coffee
All of a sudden, the amount of water being delivered for coffee has almost doubled. a single cup is delivering approx. 8oz and double coffee is over 12oz. consequently, the coffee is weak. this is a new issue. thanks.
    Habit-Forming:
  • DeLonghi Expert
  • 147 Answers
Coffee is too large, decrease larger than the button inside the beans.Turn it to a smaller number.
Posted on Nov 28, 2013
SOURCE: Delivers only small amount of coffee per brewed cup
This is a scale issue. All water has minerals wich builds up inside the brewer through time. All you need is white distilled vinegar. Drain the Keurig first and then fill it with the vinegar. After the heat reaches brewing temperature, open and close the drawer to run off a few blanks (3 to 4 cups is plenty). This will prime the vinegar though all the lines. Refill the tank to the top with more vinegar and let the brewer sit (on) over night. The next morning, run off more than half of the vinegar. You should see the cup sizes drastically increase. Within a few cups, you should be getting close to the original 8oz cup. Repeat a few times for good measure. Drain the remaining vinegar, then flush a couple full tanks of good water through it. After all remnants of vinegar is gone, your brewer should work like new.
Posted on Jun 25, 2008
SOURCE: Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 13 Answers
SOURCE: My Kerig machine started shorting the amount of
Sounds like you need to de-scale the coffee maker. Use white vinegar instead of water, and run it through until the vinegar is gone (no coffee or filter basket). Then use clean cold water to purge all the vinegar by running the water through the system the same way.
If this doesn't work, and you've purchased your coffee maker within the last year, try giving Keurig a call at 866-901-BREW. Explain your problem, and they may be able to help you or offer you some sort of replacement.
Posted on Mar 01, 2011
heatman101
  • 43501 Answers
SOURCE: I have a model which offers 3 sizes of coffee.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
My machine is not delivering the same amount of water to the three different cup size?
It might be time to clean your Keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
Mar 27, 2015 | Keurig Coffee Makers & Espresso Machines
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Coffee espresso machine is delivering too much water when requesting a single or double coffee. the expesso requests seem to be okay.
press the coffee button and hold it until it prepared the coffee.When decide that enough amount of coffee in the cup, run button and the machine will store the new length.
Nov 24, 2013 | DeLonghi Coffee Makers & Espresso Machines
Magimix Essenza M100 - purchase last week Is there a way of selecting cup size to adjust volume of water delivered? or Do I have to manually switch off the water flow?
It depends if you have a manual or an automatic machine. If you're not sure, the manual one has just one green button, whereas the automatic has two. The automatic one delivers a fixed amount of water, which you can vary but following the instructions. If you have a manual one then you need to press the button once to start the flow, and again to turn it off.
Hope this helps. :o)
Aug 18, 2011 | Magimix L'Expresso Espresso Machine
My Kerig machine started shorting the amount of water delivered. Choosing the 8oz gives about 6 oz of liquid; same for 10oz giving 8oz,
Feb 28, 2011 | Keurig B60 Coffee Maker
My single cup portofilter on my ECM Giotto suddendly is pouring more coffee then it should. I'm using the same grind I've been using forever. My other portofilter (2 cup) works fine and still produces the...
How old is the coffee being used? Normally if you change baskets, the grind should be the same, because the single basket has finer and less holes in it than the double basket. The only difference would be the tamp then, since the coffee grinds works great with the double basket. You would also have to use a different volume of water to produce the coffee. To produce 2 ounces of espresso you need about 3 ozs of water,(about an ounces of water will remain in the coffee).
Jul 19, 2009 | ECM Giotto Espresso Machine
I get the same amount of water through the espresso side whether I choose 1 cup or 2 cups. So if I use the one cup espresso holder & that much espresso it is watered down.
In a properly working machine you should get about 50 ml (1.5 ounces) for the single and about 100 ml for the double. The amount is also programmable and just about the only way to get the same amount is to program both to deliver the same amount. The unit has a flow meter to accurately measure the amount of water going to the espresso. Try the program function to reset the amount for single and double.
Oct 14, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups xp2070
In my case the problem was a faulty flow meter. I replaced the flow meter and the unit now works great! The microcontroller expects water flow information to deliver the right amount of liquid. If the unit is not getting flow information it will stop and start blinking.
Oct 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
155 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
