Question about Bosch PowerStar AE115 Tankless Water Heater...
Powerstar ae125 runs hot then cold in shower - Bosch PowerStar AE115 Tankless Water Heater...
    New Friend:
I have AE125 that I decalcify (delime, descale) once every 3-4 months. If you don't you will get gray gravelly discharge if your water has high calcium content, in a short time this will clog all your faucets creating low water flow conditions which prevents your heater from turning on. To prevent this problem you should install a high temperature filter with a stainless steel screen on the hot water discharge side of the heater & flush it once a month.
Next you MUST descale the leftside heater element or it will literally burnout from rockhard scale deposition on the copper coil of the heater element. This scale is the same stuff you've seen coming out your faucets & is the surest sign if you don't act within a few days to descale the element that it will soon burnout.
The ONLY good way to descale is to remove the 6 screws around the top of the canister & pry the coil out with a flathead screwdriver, remove electrical connectors first & label them with tags to remind you what terminals to reinstall them on. Immerse the coil into a suitable depth of white distilled vinegar for several hours. When you see bright red copper up through the center & all around the coil then you're good to go.
While the coil is basking in the vinegar bath you need to clean out the canister from which you removed the coil, it will probably be filled with the loose gray gravelly stuff that's been coming out of your faucets.
Posted on Nov 01, 2016
  • 30 Answers
Increase your flow, sounds like you are right at your activation rate.
1 way is to turn down the temp on the machine, so you dont have to mix in so much cold at your shower. Check to see if your mixing valve is bad, or your showerhead has restriction/scale built up in it.The other way is to turn on your lavatory fixture full hot before showering(which will keep hot water flowing through the machine as you adjust your temp to be comfortable.
Posted on May 06, 2014
4 Suggested Answers
electro1100
SOURCE: PowerStar AE125 seems to have failed
the circuit board is gone bad, try this, with power off reset the overload on the heater.Turn power back on and turn on water to the unit. with no taps open hold the pipe near the left element for a few minutes. it will most likely getting verry hot and trip the overload.(this is done with no water running and power on to the unit).you may even hear the water in the left elemnet start to boil or sizle. the reason for this is the triacs on the cir board are bad.I have troubleshoot this troblem many times. the design is bad and their in now a new unit (redesign) out . bosch knows their junk and wont cover them beyond 1 yr. one way around it is call tech at bosch and tell them its leaking. the u will get one of the new designs. Also applies to the AE125, Rp27pt
Posted on Mar 07, 2012
  • 5245 Answers
SOURCE: How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
Posted on Sep 26, 2012
  • 5245 Answers
SOURCE: What is the gray gravely discharge coming from my PowerStar AE125 when using the hot water? It plugs up the faucet and shower heads within minutes and almost completely blocks the water flow.
Heating water can peculate chemicals out of water, such as metals and organics.
Especially above 138 degrees.
Have well water tested.
Turn down thermostat temperature.
Or reasonably harmless well-water bacteria can react with anode rod, or other reaction in softener, to produce colored water, and smells.
Different water can produce different sludges, brown, red, gray, black, yellow.
The sludge can also combine with deteriorating pipe flakes to clog water flow.
Sludge can accumulate over years in low spots in pipes, or at elbows and constrictions.
Have plumber flush pipes.
Or run new pipes.
Also delime tankless yearly, and flush with white vinegar as shown in product manual, and treat bacteria with H2O2 hydrogen peroxide.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Posted on Oct 30, 2012
Or run new pipes.
Oct 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Electric bill doubled last month, and we've had the Powerstar AE125 tankless electric for over a year. There are no leaky faucets.
There are a lot of other things that eat electricity. Like space heater and using ovens for heat. Heat pump.Central heat fan running all the time. House lights left on. Outside flood lights. Clothes washer using HOT water. Look around real good. It all adds up. Also the power co. may be charging more for "fuel" costs surcharges. Here in GA I'm paying a bit more now to pay for a nuclear power plant.
Dec 26, 2011 | Bosch PowerStar AE125 AE125 Whole House...
When i am taking a bath or a shower somtimes it kicks my breaker what would cause this and how do i fix it
Does the panel box have the proper size breaker for this unit.Iwould start with checking that before any thing else. hope this works
Jan 23, 2011 | Bosch PowerStar AE125 AE125 Whole House...
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Heater is ae125 is about 2.5 years old no problem until now turned on water and but no hot water light or anything checked breakers,checked cutouts,plenty of flow,still no hot water
Hey did you ever get this fixed mine is almost the exact same thing we've been using ours for about 3 years and today nothing. Thanks for your help.
Dec 07, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Easiboost power shower - problem
it comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Feb 17, 2009 | Bosch PowerStar AE125 AE125 Whole House...
You have a blown element. If you purchased the heater, call Bosch for technical assistance, and the unit should be under warranty. The grey matter your getting is the magnesium that the elements have in them.
Nov 12, 2008 | Bosch PowerStar AE125 AE125 Whole House...
Bosch PowerStar AE115 Tankless Water Heater... Logo
354 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
