Question about Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator
Need to replace evaporator motor
Need schematics
    Champion:
    Habit-Forming:
  • 279 Answers
There is no such thing as an evaporator motor, do you mean The Compressor, if so that's a job for a professional only.
Posted on Nov 29, 2013
T72F fans will not run during cooling. Condensing unit runs but not the evaporator fans. Fans aren't seized up. What's going on?
Evaporator fans must be running at same time as condenser fan. Check schematic to locate source of problem Is power reaching the motor?
Aug 06, 2015 | Refrigerators
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Whirlpool fridge quit cooling
when you adjust the tempreture dial for the refrigerator this would turn on the evaporator fan motor located behind the rear wall of the freezer click this link http://c.searspartsdirect.com/lis_png/PLDM/00052094-00007.png part number 17 on the schematic would be the panel that you would remove when you remove this panel this would give you access to the evaporator coil as well as the evaporator fan motor if the fan is not spinning then you would replace the evaporator fan motor. If you see any ice build up on the evaporator coil or the fan motor or blocking the drain located under the evaporator coil this is termed as a defrost issue. If you find this then message me back and I will give further instruction on how to diagnose why your unit is haveing a defrost issue. The freezer is the only area that produces cold in a refrigerator. The evaporator fan motor blows the cold air through a small damper door that opens and closes depending on the tempreture inside the refrigerator. The first thing to check is the fan motor that is behind the panel that I mentioned. If you remove the panel and find that the fan is blowing and spinning message me back for further diagnosis. I await your reply Thank you
Rick
P.s what is the tempreture inside the freezer currently?
Oct 23, 2011 | Refrigerators
The evaporator fan is not working. Is there a schematic online for this Refrigerator?
I am not sure if their a schematic online for that brand but the circuit is going to be like this
120 volts at plug
neutral side of fan wired directly at all times
Hot side from plug into thermostat
out of thermostat into defrost timer
out of timer to evap fan motor
hot from,plug to t-stat to defrost timer finally to evap. fan plus neutral side at evep motor makes it run
Aug 15, 2011 | Sanyo SR1031S Refrigerator
Need schematic for evaporative purge valve installation 3.8 motor
Go to a local repair shop with a data base,
they should print what you need
Ask if they have ALLDATA,Mitchell or Motor
Mar 16, 2011 | 1994 Ford Taurus
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
If the motor is getting power and not running you will need to replace it. This is a fairly common failure in these models. We have the part in stock for under $45 your part # is AP3875639
enter the part# or your model # at www.appliancehelponline.com
Jul 12, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Not cooling
hi thanks for the question i would replace the fan motor in freezer thanks the appliance doc
Sep 25, 2008 | Hotpoint HSS25GFP Side by Side...
Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
