Question about Dryers
My fan for my heater does not work why?
Fan does not run when turned on why?
    New Friend:
  • 92 Answers
I can recommend you find the manual on this site:
http://lightingworldbay.com/
Posted on Dec 19, 2013
Why does radiator fan work when air is on but not when heater is on?
Have you waited long enough?
Sometimes it can take 5 -10 minutes before it turns on while using heater.
Oct 22, 2015 | Toyota RAV4 Cars & Trucks
Ok when I have my heat fan on my 2006 dodge charger 2.17 it dont run hot but when I turn it off it do our when I turn on the ac it run hot
If the engine is running hot you may be low on coolant. Check this first. If coolant level ok, the rad fan may not be working to cool the engine. If the AC is operational, when you turn it on, the radiator fan should come on telling you the fan motor is ok. You still may have an issue with a fan control related to temperature. This can be caused by a fan relay/wiring/temp sensor/ecm. Make sure the thermostat is functioning properly as well
Jun 21, 2015 | Dodge Cars & Trucks
RE: Bionaire BSF1620RC Pedestal Fan - blades won't turn. I have had this fan for about 4 years - 2 of which the fan has been stored. It was well protected so I don't know why it isn't working. but the...
These run very small motors with low "starting torque" If the fan hasn't been run for a long time, its possible that it has jammed up or got tight from just sitting there. Being careful, turn on the fan and spin it in its usual direction by hand, it should start running. If you cannot spin by hand, it may have seized up which will require you to strip and lube the motor. If you manage to get the fan spinning , let it run on high fan speed for an hour or so, it should free up and then be OK again. A small spray of WD40, CRC or similar spray can lube on the fan shaft where it disappears into the motor may assist.
Feb 03, 2015 | Bionaire Dryers
Radiator fan running when the cockpit heater is ON
If you you are running it in Defrost the A/C will turn on to dry the air thus turning on the Rad fan also check to see if your A/C switch is turned on.
Feb 15, 2013 | 2004 Volkswagen Passat
My 02 nissan pathfinder interior fan runs even when not turned on.checked all fuses they seem to be fine.
If fan still runs when all your heater control knobs and buttons are off, it is likely a bad heater fan switch. Unless you have something like a body control module found on newer cars that has some control over interior functions. If not, try a new heater fan switch. Good luck.
Jan 18, 2012 | Cars & Trucks
When I turn the heater on, the motor sounds like it wants to turn but there isn't any heat coming out
the fan will run whether or not the heater core is getting warm, it does not care. you can hear the fan run, sounds like a fan running. if there is air coming out the vents and you hear the fan running, then the problem lies with the heater core.
Dec 16, 2010 | 2004 Mitsubishi Galant
Heater problem
is your heater set on defrost this will cause your engine fan to run because it turns on the compressor for air conditioner this helps to extract moisture from your warm air defrost  and the fan in the engine compartment helps keep it the engine cool from the extra load on the engine this is normal
Feb 17, 2009 | 2003 Hyundai Santa Fe
2001 s-10 Heater fan works intermittenly
Replace Fan or possibly thermostat module
Jul 08, 2017 | 1996 Chevrolet Blazer
Dryers Logo
24 people viewed this question
Top Dryers Experts
