Question about Poulan Garden
No spark at points
D1 vik1 tractor
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
If your talking about the coils having no spark to the spark plug
u need new coils
Posted on Nov 27, 2013
I have a 16.5 hp onan engine in a 1979 gravely tractor -with engine running why are my ignition points sparking
Ignition points open to collapse magnetic field in ignition coil to make spark. They have a condenser across the points to reduce the spark which comes because the current collapse also generates a back feed current in the now open circut in the primary windings. This is the spark that damages and wears out the points. Check with a competent Auto Electrician that the condenser (also called a Capacitator) is the right capacity for the coil being used.
Jul 20, 2014 | Garden
No spark at points
Sounds to me, if no spark to points I would suspect the coil.
Jul 06, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
David brown tractor
points shouldn't have spark but check for a bad condensor
Nov 24, 2013 | Poulan Garden
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Nov 18, 2013 | John Deere Garden
1970 b and s tractor/mower by craftsman,i have spark at points but not at spark plug
There should not be a spark at the points. If you have spark there, replace points and condensor and retry.
Dec 21, 2012 | Garden
Not getting spark all the time after putting new
Clean the points with an emery board if this doesn't fix it roll the motor until the points are open then short them with a screwdriver if it arcs see if the coil is putting out spark if not get a new coil
Dec 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
My lawn tractor won't start no spark an I have aready replaced the electrical control circuit board. It is a LX277 lawn tractor year 2000 I think. After I replaced the circuit board It still did't start I...
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Sep 10, 2009 | John Deere Garden
I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Jun 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
May 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Apr 28, 2009 | Garden
Garden Logo
19 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
