Question about Uniden BC72XLT Handheld Scanner
Backlight Can someone help me with a mod to disable the backlight timer. I would like the back light to remain on or off, depending only on operation of the button.
  • ToVVeR May 29, 2008
    I like turn on or off light without 15 seconds limitation.
  • 22 Answers
Hi
ther is only 1 option for this unit
http://www.uniden.com/pdf/BC72XLTom.pdf
page 50
-Using the Display Backlight-
To turn on the display light for easy viewing at night, press . The display lights for 15 seconds. To turn off the light sooner, press again.
other models have more options but this one doesnt
same for the 92xlt
D
Posted on Nov 21, 2007
How can I get my keyboard light to come on?
The key just to the right of the space bar is the backlight key. Pressing the backlight key scrolls through the backlight levels of OFF - LOW - MEDIUM - HIGH.
Hold down the backlight key and press the right or left arrow keys to scroll through the colors.(WHITE, RED, AMBER, GREEN, AQUA, BLUE, VIOLET).
However, when the battery is at 20% or less the backlight feature is disabled to conserve the remaining battery charge.
Jul 06, 2014 | ZAGG Folio Keyboard
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
My acer extenza 4420 backlight wont turn on
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Aug 31, 2009 | Acer Extensa 710TE Notebook
Backlight
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
May 05, 2008 | Apple iPod nano
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Sidkeick 3 backlight
Have you tried checking the Battery and Display settings from the main screen Settings menu? There is an option to enable or disable the backlight, as well as set the brightness.
There is also a setting called "Use ambient light sensor", which sets the backlight and keyboard light to only turn on if it is dark when you are using it.
Jan 14, 2008 | T-Mobile Sidekick II
Backlight on the Gameboy color
unfortunatley no there is no backlight for the gameboy color and your problem is a VERY common one.
Jul 29, 2007 | Nintendo Game Boy Color Console
Uniden BC72XLT Handheld Scanner Logo
200 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
