Question about Designtech Extra 3 Button Remote
How do i program my remote for design tech car starter
Need to get remote for autcommand model#20726
only way is to contact factory,,,they have changed name 3 times now,,so may be a hard hunt,,,may be easier to find universal remote,,but it is a gamble if it will program,,,technology has changed so much since that model came out
Apr 24, 2014 | AutoCommand Remote Car Starter Add-On
I have an auto command remote starter, model #26327/v1.0/75x/3602. I am looking for an installation manual, my remote starter does not work, it is flashing 3 times. Thanks.
Check your manual, when it honks or blinks at you it is telling you what is wrong (see my tip in my profile) . It usually will tell you what is wrong and is usually an easy fix.
Jan 20, 2011 | AutoCommand Remote Car Starter Add-On
My car starter is not working. When I push the start button I can hear a click and the parking lights turn on and off again, and then nothing. It doesn't turn over at all.
my car starter quit working. light on the mirror sensor stays on all the time it used to blink off and on. also the dr locks still work when using the remote
Nov 26, 2010 | AutoCommand Remote Car Starter Add-On
My starter keeps going when bulldog remote starter is hooked up
sounds like the tach wire may be coroded or been disconected, check under the hood for a single wire going to the ignition coil or a fuel injector for good connection
Nov 12, 2009 | AutoCommand Remote Car Starter Add-On
Remote starter
It sounds like your car is hooked up for voltage sense instead of running a tachometer wire. If you have run a tach wire you'll need to program the tach signal and make sure your remote start options are set for that.
Oct 09, 2009 | AutoCommand Remote Car Starter Add-On
Starter stays engaged
you need to tell us the make model and year of the vehicle and the kind of remote starter u have installed on the vehicle
Starter Stays Engaged
check the wire that is hooked to the starter wire on the car. it should only show pwer in the start posision
Nov 19, 2008 | AutoCommand Remote Car Starter Add-On
Designtech Extra 3 Button Remote Logo
26 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
