Question about Sharp LC 37A63M 37" LCD Flat Multisystem TV 110-220 volts
LCD display problem
In my Lcd display Colour is creating problems, some time it appears green and some times it red and some time vertical lines have comes but in that time, behind vertical line picture comes clear, no green or red issue plz answer me which board is creating problem
  • Sharp Master
  • 2,072 Answers
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Posted on Nov 24, 2013
A red line appeared vertically, is this a hardware problem?
I would go back where it was purchased and press the issue, since it is so close to the warranty time they may make exception, because the alternative is replacing your monitor. There is a large printed circuit board on the back of the LCD that processes the video and colour images that has become defective and is part of the LCD display.
Apr 24, 2012 | Samsung Syncmaster 2033SW Monitor
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
Vertical green line on left side of my laptop lcd
lenovo G450 a vertical line appears on the right side of screen. it is of pink colour.
Jul 03, 2010 | Samsung 204T 20.1" TFT-LCD Monitor
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Apr 01, 2009 | Sony VAIO VGN-FS640W Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Sharp LC 37A63M 37" LCD Flat Multisystem TV 110-220 volts Logo
69 people viewed this question
Top Sharp Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Daniel Dollive
Daniel Dollive
ismael castillo
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
