Question about Maytag Neptune MAH5500B Front Load Washer
Water fills constantly
Water fills even if washer is off
  • 101 Answers
Inlet water valve stuck open, usually because the filter is damaged or non-existent, dismantle valve clean out foreign matter or replace valve.
Posted on Dec 21, 2013
Why does water constantly trickle into washer even if water to washer is turned off? (Crosley top loader)
Could be a fill valve that doesn't shut off completely. Some manufacturers recommend turning off the supply between wash sessions.
May 20, 2015 | Washing Machines
The washer keeps getting the water in even when the washer is not in use. there is constant water drifting along the rubber ring of the front door into the container
check fill hoses screens for silt,dirt also at the water valve screen. if dirty clean and replace the screens at hoses and clean screen at valve. if this wont work make sure water pressure is at least 20psi. if it is replace water valve if problem not solve or continue.
Feb 08, 2011 | Kenmore HE3T Washer
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
The cold water is constantly running in the machine. It runs through all cycles and even when the machine is off.
Water fill valve is bad. This is where the hot and cold water connects to back of washer. Common problem, gets loaded with sediment
Dec 29, 2009 | GE WBSR3140DW Top Load Washer
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
My washer won't stop filling up with water!
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
May 29, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Washer does not fill with water
The problem is most likely that your drain valve is defective. If this happens, the water will pump out instead of circulating. There may also be something stuck in the drain valve causing it to stay open.
If you need more help, post a comment.
Thanks,
Tim
May 28, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
