My Whirlpool AW0D 6120 IS DEAD. No lights or any sign of power. I have checked the plug and fuse which are ok so power is to the machine. Would it be the control panel? e mail bm.bl64@yahoo.com
  • 209 Answers
SOURCE: Hotpoint WF860
when the machine was flashing door this was telling you that either the door was not shut properly, try it again, or the interlock switch was faulty, chances are its probably shorted out and blown the circuit board, take care and remove the board to check for signs of blowing, if no signs then i would replace the interlock and start from there, ps i am a retired engineer and have had the same machine myself
Posted on Oct 02, 2007
  • 833 Answers
SOURCE: microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Posted on Dec 20, 2007
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
Posted on Apr 01, 2008
robotek
  • 1512 Answers
SOURCE: Dead Arcam CD73
Hi 2002tii
These are a cool old machine. They use the cdm1 laser mechanism that was revered in its day for high performance. If you have voltage available after the rectifier stages, check the 3 pin voltage regulators. Marked as 78xx for positive regulator, and 79xx for negative. the xx gives you the voltage they are supposed to be putting out. They commonly fail, also check the same for dry solder joint. resolder them anyway if you are unsure. If all the regulators check out, then also check low value flame proof resistors in the power supply rails. Get back to me here again and let me know how you got on. Good Luck
regards
robotek
Posted on Aug 09, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
Hi,My whirlpool AWO/D 8140 appears dead there is power going to the machine but there are no lights on. Is this fixable
probably the circuitboard. you should call a household technician to check the machine and if not i'm afraid it will need to be replaced
Aug 13, 2017 | Whirlpool Washing Machines
GE oven is completely unresponsive but I have power to the plug that goes to the board. I see no obvious signs of damage, no burnt anything, not even a smell of burnt stuff.
Hi, Did you check the fuses on the stove. If it was built before and after model year 2000 there still should be fuses. If your stove is still under warrenty you may be able to get it fixxed for free. Good luck.
Feb 21, 2015 | GE Microwave Ovens
Hitach lcd tv dead, no standby light. Power board Vestel 17pw26-1 v4 no signs of burnout/swolen caps.
You can pick up a cheap multimeter at radio shack, or Harbor Freight (if one is in your town). Or of you know someone who has a multimeter you could borrow, that would be even better. You will want to set your meter to ac volts, and check for 110vac across the input terminal on the power supply board. I'm willing to bet you have a dead power supply.
Dec 09, 2012 | Hitachi Televison & Video
Whirlpool dryer dead no power to buttons
I reckon you should take the panel cover off and check the main in line fuse.Assuming you have checked the main fuse.And is ok.There wii be a small white case which has the fuse inside it.The best of luck.
Aug 14, 2012 | Whirlpool Dryers
We have a whirlpool AWM6140/3 1400 spinspeed when I turned machine on it fused the supply at the fuse box not the plug,now it won't turn on
hello because there a dead short somewhere the fuse inside the washer power supply could have blown if this ok you will need to check wiring if ok then there could be a fault with the power supply board hope it helps
regards
shaun
Jan 08, 2011 | Whirlpool AWM6140 Front Load Washer
No power to Whirlpool Condenser Dryer AWZ7813
check your wall plug it could have went out
Jan 29, 2010 | Dryers
Whirlpool Duet Dryer
Friend,
huuum At your service!
You said:
Everything was working fine, now we get no panel lights, the dryer light doesn't, dead in the water! Checked the plug...unplugged it and plugged it back in. Checked the circuit breaker...ok. What next?
I'm sorry to tell you that you need hands on service.
If I were there hands on I could diagnose the problem.
You may have an electronic malfunction and that only a trained technician can diagnose!
SORRY!
Bless You,
huuum
Please give me a good rating before you sign off
thank You
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Microwave jsut went dead. No power, and there is power at the outlet.
check the fuse inside, watch out with those can capacitors as they can give you a nasty shock. For your protection unplug the microwave and wait 24 hours to let the capacitors discharge, then open and find fuse which is usually near the power supply, check fuse, if dead replace it.
Josh, South Carolina
May 03, 2008 | Whirlpool Microwave Ovens
Whirlpool Miccrowave (GH7145XFQ-1) went dead...
Does the display light up?
Are you sure it is getting power?
Check that and get back to us cause the next step is going inside
Jan 01, 2008 | Whirlpool GH7145XF Microwave Oven
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
