Question about Graco Pack 'n Play
Center wont stay locked
One of the white pieces attached to the red cord at the bottom of the pack 'n play came out so the center wont lock
4 Suggested Answers
  • 6 Answers
SOURCE: how do i get the sides to lock/ stay up on my
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
Posted on Jun 14, 2009
  • 125 Answers
SOURCE: pack-n-play will not break down when trying to
will rlese if you turn and pull the center of the cot and then pull up till you feel that it's done.
it's treaky and coming back blocked very fast. you have handle all of them at the same time
Good luck.
Meggita
Posted on Sep 25, 2009
  • 679 Answers
SOURCE: i have a pack and play that will not lock at the
the center of the pen must be up the do the sides while the middle is up then push the center down.
Posted on Jan 26, 2011
I am trying to find the ground wire for this dryer.
On whirlpool (all manufacture) dryers the ground wire is linked to the center terminal with the white wire and attaches to the cabinet grounding all metal on dryer since on panel attaches to the next making the entire cabinet have continuty through the neutral/ground wire.
When connecting 3 wire cord connect the two outside wires to red/black on cord block and center wire to white/center terminal connection on block.
For a 4 wire cord red to red black to black white to white and the green to rear of cabinet/any panel near block
Aug 13, 2011 | Whirlpool WED5100VQ Electric Dryer
I am installing a 30 amp cord on my Whirlpool dryer. The model number is WED5100VQ. I am having a problem finding the ground wire in which to ground the dryer because it only has a white wire coming from...
(same question listed 2 times gets same answer 2 times)
Aug 13, 2011 | Whirlpool Dryers
I have a pack and play that will not lock at the bottom and i was wondering if there was any way someone could help me
Jan 26, 2011 | Graco Pack 'n Play
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How do i hook up my dryer from a 3 prong to a 4 prong
UNPLUG DRYER FIRST.
Remove old cord from back of dryer. Make note of where white, back and red wire hook to on piece of paper.
New cord has 4 wires. looking at the back of dryer,
RED Wire, should have been tied to terminal screw on right side,
WHITE Wire, should have been tied to center terminal,
BLACK Wire, should have been tied to left terminal,
Remaining wire is GREEN, attach to body ground screw located next to cover plate, screw is generally painted green. IF not attach to unit body.
Oct 01, 2009 | GE DCVH515EFWW Electric Dryer
How do you set up a pack and play?
Open it part way but do not push the center of the bottom all the way down. Raise each of the side rails and make sure they lock in place in the full up position, When all four side rails are locked in place, push the bottom center all the way down until it locks. Put the the bottom pad in place and secure it with the velcro tabs through the opening in the sides.
Jul 06, 2009 | Baby Gear
How do i get the sides to lock/ stay up on my Graco Pack and Play?
Jun 13, 2009 | Graco Pack 'n Play
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
May 23, 2009 | LG DLE2512W Electric Dryer
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Graco Pack 'n Play Logo
37 people viewed this question
Top Graco Toys Experts
Shehu Pro
Shehu Pro
ray gallant
thegtw
Are you a Graco Toy Expert? Answer questions, earn points and help others
