Question about Powermate Vx Series 3000 Watt Portable Generator - PM0103007
I think my fuel line is frozen its was 8 degrees over night my generator has been sitting out side
    Prodigy:
    An expert who has answered 500 questions.
  • Powermate Expert
  • 573 Answers
It isn't likely fuel line has frozen, I would suspect more the oil is like glue, and the battery is probably shot. You may wish to consider a cold weather kit, you can get other brand OEM oil heaters that screw in the drain plug hole, battery electric blanket, and alternator strip adhesive heaters.
Posted on Nov 25, 2013
High-pitched chirp at same time every night
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Feb 16, 2014 | Refrigerators
Kenmore freezer drawer frozen shut
use your wife's electric handheld hair dryer as close to the rails as you can once slightly open you can use table salt/ice melt to free the drawer or; turn up your house thermostat to about 80 degrees for the day while you are at work; the drawer should be free by the time you get home.
Nov 18, 2013 | Freezers
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
I have a 98 sunfire that will start but shuts off after about 3 seconds. It was running perfectly fine the night before, but about 14 hours later the problem occurred. The car has no power locks, power...
If it's been very cold you may have a frozen fuel line. Put some isopropel type fuel dryer in it and let it sit for a while before tring to restart it.
Jan 12, 2011 | Pontiac Sunfire Cars & Trucks
Yamaha 5700 manual start gen. Pulls but will not start, fresh oil. And I"m at 5600 feet. And outside temp. Is about 38 degrees.
What have you tried so far? An engine needs fuel, air and spark to work properly.
Fuel - Has the generator been sitting for more than a couple of months? There could be bad gas in it, and/or varnish built up inside somewhere in the fuel tank/lines. The carburetor could be plugged somewhere blocking proper fuel delivery.
Air - The choke may not be working/applied properly, or the air filter clogged.
Spark - The spark plug could be fouled, have you tried seeing if there is spark or not? Is the spark plug wire on tight, is it the correct one, is it clean and gapped properly, etc?
Nov 10, 2010 | Yamaha Electrical Supplies
Car runs good in AM to work then sits for 8 hours. When started in the PM it stutters badly until running at hiway speeds. Just changed plugs, plug wires d cap and rotor, valve body flush, injector...
Could be your air temp sensor. Its cool in tha AM and hot in the afternoon. Your van may think its 200 degrees out side and adjusts fuel / timing acordingly. Hope this helps
Aug 06, 2010 | 1996 Dodge Caravan
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Powermate Vx Series 3000 Watt Portable Generator - PM0103007 Logo
61 people viewed this question
Top Powermate Electrical Supplies Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
obdcs
Level 1 Expert
Are you a Powermate Electrical Supply Expert? Answer questions, earn points and help others
