Question about Microsoft VISTA Computers & Internet
Will not boot up - VISTA Microsoft Computers & Internet
  • 68 Answers
Start in safe mode and see if one of your drivers is preventing VISTA to start. Press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
Posted on Dec 21, 2013
What can I do to boot my PC without using the F8 key?
If you have to select the boot device every time, this means that the BIOS (CMOS) setup does not have the boot device listed as the first device to boot from. At startup, press the key that enters CMOS (BIOS), usually DELETE, or possibly F2. Once in the CMOS, look for boot options, then boot devices, then boot sequence. Find your device and ensure that it is listed first in the boot order sequence. Then save the changes and reboot. You may have it set for a USB or network boot first and it won't boot without intervention.
Aug 15, 2016 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
Is it possible to make two hard drives into boot devices?
Yes. It is called "Dual Boot" or "Multi-boot". You can even have different operating systems on each drive or partition. For more information, just click this link.
Feb 16, 2011 | Sony VAIO Digital Studio PCV-RS410 PC...
Why won't my computer boot to the A drive?
Because the BIOS is probably set to boot the hard drive first. The A drive, second or third depending on the boot order set in the BIOS.
Nov 23, 2010 | Computers & Internet
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Snowboard boot type
"Snowboard Boots - Function and Types of Snowboarding Boots Good Snowboard Boots should give you maximum control over your Snowboard, protect your feet and ankles from the pressures of high speed turns, and keep your feet warm and breathing in all weather conditions at the same time. Boots come in many variations and Styles. There are Different Types of Snowboard Boots appropriate for the Three Riding Styles in Snowboarding. Currently, a lot of boarders prefer soft boots with Strap Snowboard Bindings, but step-ins are a convenient alternative. What follows are descriptions of the most common types of Snowboard Boots: Soft Boots Softboot Soft Boots are most comfortable and can be used with highback bindings and flow-in bindings. This type of Snowboard Boots allows for a large amount of movement in just about any direction. Consequently, soft boots are a must for pulling tricks since they are great for doing whatever you want. Soft Boots consist of two parts: an inner bladder and an outer boot. The inner bladder is padded to keep your feet warm, dry and protected from heavy impacts. It usually has its own lacing so you can tighten the inner bladder independently from the outer boot. The outer boot has a sturdy upper part that allows for ankle movement. The outer lacing allows you to further tighten the Boots. In contrast to Hard Boots and Ski Boots, Soft Boots are pretty comfortable for walking and even driving your car when you're not on the board. Soft Boots are currently the Most Popular Type of Snowboard Boots and are preferred by Freestylers and Freeriders. Although there is a wide range of Soft Boot Styles for both Freestyle and Freeride Snowboarding, the main difference in the different styles is in the degree of Boot Flex. Soft Boots with a stiffer upper boot and a higher cuff with a lace-up inner boot for enhanced firmness are Freeride Soft Boot Styles. Conversely, Soft Boots with loose, molded-foam inner boots for more flexibility are Freestyle Soft Boots. Hard Boots Hardboot This Type of Snowboard Boots is designed for precise control. Hard Boots support your foot, ankle, and lower leg firmly, making them best for racing and high-speed carving on hard snow. Hard Boots have a padded inner bladder similar to the ones in Soft Boots. The outer shell however is made out of hard plastic and is usually adjusted (or closed) using buckles or ratchet bails. The benefit of having hard plastic as an outer shell is that it gives riders more precision and power in edging movements. Hard Boots resemble the traditional Ski Boots. However, the Hard Boots have lateral mobility for the ankle. To provide some flexibility, hinges are often built into the ankles. The soles of Hard Boots usually have a mechanism that allows them to be connected to Plate Bindings. Hard Boots are often used with plate bindings by Alpine Racers who want their movement to be directly transferred from the Hard Boots and Snowboard Bindings onto the Snowboard. On the contrary, Hard Boots are not suitable for Freestyle Snowboarding tricks and maneuvers since they limit the amount of flexibility. This Type of Snowboard Boots is pretty specific and seriously lessens your freedom in choice. If you're planning to buy this, make sure you find an exact match between the Binding Mechanism and the Hard Boot Mechanism. Also, make sure you can flex the Hard Boot forward easily and smoothly so as to avoid mishaps during transitions. Hybrid Step-In Boots Hybrid boot These Snowboard Boots are a good choice for those who want the convenience of a strapless system. Hybrid Step-in Boots combine the flexible, soft upper part of Soft Boots and the sturdy hard soles of Hard Boots. They are used in combination with Step-in Bindings. People who are looking for a mix between the comfort and flexibility of Soft Boots and the control of Hard Boots will often opt for Hybrid Step-in Boots. As with Hard Boots, you will need to find a match between the Step-in Binding mechanism and the Boot mechanism. Before you buy Snowboard Boots, you must first decide whether you want to go with a Step-in Binding or a traditional Strap Binding. Remember, while traditional Strap Bindings will work with any non-Step-in Boots, Step-in Boots must be purchased together with their corresponding Bindings. Also, keep in mind that Hard Boot systems work best in harder snow conditions, while soft boot systems work best in softer conditions. "
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
