Question about Xerox Phaser 7760/YDX Laser Printer
Damage of Transfer Unit
Each time we put a new Transfer Unit the printer would cut/damage the belt.
    Guru:
  • 110 Answers
Are you changing the whole belt unit or just the belt with the same belt frame.
Some times the frames get bent and that eventually starts sliding the belt to one side causing it to rip. If you are changing the whole belt unit and it keeps on doing it then you might have some parts either broken or damaged.
Take the Transfer unit out and with a flash light make sure the Belt lift assembly is not bent and it easily raises the belt up and down.
Take out the Image unite(make sure you protect them from the light) and put in one at a time to make sure you are putting them in correctly, make sure they light up evenly.
One last thing you might want to look at is the erase lamps to make sure they are not bent and are still in place.
Hope this helps......
Iteminconline
Posted on Nov 26, 2013
Ricoh 4501MPC copier keep damaging the transfer belts
It's purely mechanical problem. Kindly check the proper position of the transfer belt and check very well if there is a particular part that is not properly fixed or out of position. Also observe closely which side the damage comes from
Apr 25, 2016 | Ricoh Aficio Office Equipment & Supplies
Door stack on konica minolta c 253
Did some one install a new unit such as a transfer belt or transfer roller? Or a fusing unit? Recommend a technician look at it unless you want to yank it open and do some more damage?
Sep 01, 2014 | Konica Minolta Bizhub C253 Copier
Need to replace the transfer unit on a bizhub c352
open the right side door, you will see a shined belt do not touch especially the new one that is what put the image on the paper nick it or damage it in any way your prints and copies will reflect you mistake, in the machine you will see to handles at each end of the the belt, below them one screw each side. when you release the screws the two metal plate should come part way out do not yank be gental pull then grab both handles and pull /slide the unit out. if this is your first time might pull out the 4 drums to you dont nick them in installing the new unit, I must say I would pay the a tech to come do and have him show you all the things to look out four my opinion
Feb 17, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
Printing shadow from previous page
transfer belt damage please replace transfer belt or transfer belt wiper blade
Sep 28, 2011 | Samsung CLP-500, 550 Image Transfer Unit
Vw lt46 1998 would it damage valves if timing belt
yes it will and most likely put a hole in the piston and snap the cam shaft if the engine is doing any more than idle speed, if it breaks at idle you may be lucky and just get away with a few bent valves but if im honest ive never seen anyone be lucky with one the normaly require a new engine. also worth changing the water pump at the same time as these do seize and will snap the new cam belt ! the only belt you can get away with leaving is the pump belt if this breaks no damage is caused the engine will just cut out ! however you will need to pretty much remove it after fitting a cambelt to set the timing so its pretty pointless no to change it
Apr 15, 2010 | 1997 Volkswagen Eurovan
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
Printer was off for two weeks and now error sc471
SC471 means: Belt tension unit cam error. Even though the belt tension unit tires to return to its home position several times, the home position sensor is not activated.
Possible Causes:
Defective transfer belt unit.
Defective transfer belt tension unit.
CN25 Pin 3 on the engine board is unable to send a signal.
Suggested fixes:
Replace the transfer belt unit.
Replace the engine control board.
Replace the transfer belt tension unit.
I would start by opening it up and inspecting the transfer belt and associated parts. Pull them out and re-seat them. Look for broken wires, stripped gears, gunk in the works. Clean it, then put it back together and test.
If you aren't up to it, it is probably time to call the repair man.
Dec 16, 2008 | Ricoh Aficio CL2000N Laser Printer
Transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Jun 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Xerox Phaser 7300 Error U20
1. Contaminated or damaged Imaging unit contacts. - Remove and clean the contacts and inspect for damage.
TROUBLESHOOTING TIPS AND HINTS:
Imaging Unit Failure message occurs because the printer cannot detect imaging unit motion, up-and-down. The Transfer Belt drives this motion, and the Drum Contact Assembly detects it. 1. Swap the Imaging Unit Cotact blocks between two imaging unit positions. If the problem follows the Contact block, it should be replaced. 2. Open the Top Cover and defete the top cover interlock switch. The color imaging units should raise in succession, cyan, magenta, then yellow, and then all lower at once. If one or more imaging units do not raise smoothly or drop prematurely then replace the Transfer Belt assembly.
Apr 29, 2008 | Office Equipment & Supplies
Xerox Phaser 7760/YDX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
