Question about Air Tools & Compressors
Chicago electric model 66783
Where can I find an electrical schematic, wiring diagram, or a photo of the internal wiring of this battery charger?
  • Jerry Mercks
    Jerry Mercks Nov 26, 2013
    I do not know why the program listed this as an air impact wrench. It is a battery charger, Chicago Electric Model # 66783. The problem is simply that a wire has come loose on the setting switch. A photo, schematic, or wiring diagram would give me the information I need.
  • 659 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
SOURCE: Suzuki wiring diagram
http://www.suzuki-club.ru/forum/downloads.php?do=cat&id=5
Posted on Jun 01, 2009
  • 10 Answers
SOURCE: Wiring/electrical schematic info for a 2000 chevy express van
Check www.autozone.com.
Posted on Jun 14, 2009
  • 245 Answers
SOURCE: Looking for a wiring diagram for a Yamaha BWS 50
The service manual has a diagram, but you need to zoom in to read the colors.
You can download a free one at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
Posted on Nov 21, 2009
  • 6 Answers
SOURCE: I tried to charge my car battery with a Chicago
Relax, the charger is working fine. What it is doing is charging the battery to 15.5V. During this time, the "charge complete" LED is off, and the current meter shows the needle going to the right. When 15.5 volts is reached, the current is shut off, the needle goes back to the left, and the LED goes on. When the battery voltage drops to 13 volts, the current goes on again, etc. At the beginning, with a very depleted battery, the needle will be towards the right, then as the battery gets charged close to full capacity, the needle will bounce back and forth because the charger is feeding current in short pulses. Towards the very end of charging, the needle will stay longer and longer at the left end (the LED will be ON), and spend less and less time to the right (LED will be ON for longer periods, and "blink" OFF less and less). Finally, at full charge, the LED will stay ON, the needle won't make excursions to the right, etc.
Posted on Feb 06, 2010
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Free 966 international tractor wiring diagram
I don't know where there's a schematic on the web, however, the schematic is in this shop manual:
SMIH203 International Harvester Farmall Shop Manual
Good luck
Nov 03, 2014 | Toys
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
I have a 1992 Rascal, Model 240. The charger assembly has a burnt mark on it. Is there a schematic or picture of the board that I can get? My brother may be able to fix it, but he can't identif
The charger is a 24v 4 amp one stage device. Its an incredibly cheap charger. It consists of a step down transformer, a bridge rectifier, a filer capacitor, and a voltage regulator. Virtually all chargers are made this way. Generic schematics
http://www.simple-electronics.com/2011/10/24v-battery-charger-simple-and.html
This charger is built around the famous an popular LM317 chip it really simplifies things.
http://www.circuitstoday.com/24v-lead-acid-battery-charger-circu
I would get out my trusty multimeter and chase 24v though the device.
You may need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Set the meter to read VAC, you should get 30VAC out of the transformer. Next check the rectifier section, Set the meter to read VDC, the output should be about 29VDC. There is a fuse in there that you can check out. Then there is the regulator, if any part of that is fried, you're going to have a hard time finding parts. i really miss the 60's when there were electronic stores on every corner. There used to be a time when you could order your your TV as a kit. You could literally teach your kids something useful at the kitchen table. Quite frankly a 2 amp charger cost $14 4 amp cost $28. Not worth fixing really.
Chargers can be found here
http://www.amazon.com/Electric-Scooter-Battery-Charger-Prong/dp/B001GMTKN4
Jun 19, 2012 | Electric Mobility Mobility Electric Power...
Must install a replacement switch on a portable electric drill. Must have an electrical schematic diagram
If you haven't taken the old switch out yet I would take a photo of the wiring and or make a crib sheet, it you have give me the complete model number and I will try and find one for you.
Nov 16, 2010 | Craftsman Drills
I tried to charge my car battery with a Chicago Electric charger model 66783. I followed the directions for charging the battery in the vehicle. After selecting the charge rate of 10 AMPs, the ammeter...
Dec 29, 2009 | Chevrolet Classic Cars & Trucks
I need to know what each color means on my distributor???
Review this guide as reference; this Electrical Schematic Diagram applies for 1994 Accord Coupe series of model. Here you will find complete explanation about electrical system of the vehicle. Started from Troubleshooting (tips and precautions) on handling the electrical system, in this manual you will be guided step by step examining each electrical component installed and its connection for example in Wire Harness and Ground Location, started from Engine Compartment, wiring harness is shown from engine ground cable, starter cable, and battery ground cable.
These 359 pages of pdf.fieltype manual is divided into some sections which are Wire Color Code, Relay and Control Unit Location, Wire Harness and Ground Location, Air Conditioning System Circuit, Anti-lock Brake System, Battery, Blower Control, Charging System, Cruise Control, Fan Control, Fuel Pump, Fuses, Ground Distribution, Heater Control, Ignition System Control, Lighting System, and etc.
Download the complete 1994 Accord Coupe Electrical Schematic Diagram here.
You can also find complete workshop manual of 1994 Accord Coupe here.
Pass: freepdfmanual.com
Good luck.
Sep 21, 2009 | 1997 Honda Accord
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Air Tools & Compressors Logo
119 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
