Question about Garrity Industries I Beam 6V Lantern I600
Not sure about charging the light does the red light stay on during charging
Also the handle gets hot while charging.
Why will my Vizio VTAB1008 tablet not charge?
could possibly need a new battery.sorry but they do fail .
Sep 13, 2014 | Vizio Tablet VTAB1008
Red and green lights work fine, but after green off completely, help?
Generally If System Is Unused For A Certain Amount Of Time Time It Will Go Into Was Is Called Sleep Mode. Also Make Sure You Locate Your Fan And Make Sure Its Able To Pull In Air For Ventilation Which Keeps The System Cooled Down And Wont Allow System To Get Hot
Mar 17, 2012 | Sony Playstation 3 (PS3) Console
Engine light comes on and off baterry had to be jumped
You need to make sure your battery is holding a charge. Check all your battery wires and make sure they are cleaned and on tight. Your alternator may be draining your battery. Start your vehicle and take the hot side battery post off, the red side. If your vehicle dies instantly, your alternator is bad. If it stays on for a little while, it could be the connection or wires. Make sure no lights are staying on to kill the battery.
Mar 04, 2011 | 2005 Chevrolet Tahoe
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
My Flip Ultra HD has a red light that blinks when I try to charge it. It won't charge, what can I do to charge it?
Make sure you use a good USB 2 port and make sure your computer stays turned ON during the charging or it will not charge. The red light should stay on on the front of the camcorder while charging and will go off when charging is complete.
Try a different USB port maybe also. or if using a USB extension make sure it is a powered extension, and if not, connect the camcorder directly into a USB instead of using an extension.
My extension has a light to show that it is a powered extension.
Jan 31, 2011 | Flip Video Flip UltraHD 8GB High...
I just got a brand new flip video mino hd and it wont turn on. i've charged it for atleast 4 hours. when it is plugged in the red light comes on. that is the only response i get from it. any...
I had to charge mine for 7 to 9 hours the first time, and make sure computer is left ON or it won't charge and the red light stays lit until it is fully charged. make sure the red light isn't blinking if it is, plug it into a different USB 2 port and don't use extension with it unless it is a powered USB extension.
Dec 28, 2010 | Pure Digital Flip Video Ultra Camcorder
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
Indication light "RED" on continuously during operation. Unit fires up, heats up and blows hot air. Why is LED "RED" on when unit shuts down?
not knowing wich one is on, this red light could be your power indicator light..
it stays on during any operation,
you should be able to see it through the sight glass
if it were flashing,,,, there would be a problem
Oct 13, 2009 | Goodman GMS90703BXA Heater
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Garrity Industries I Beam 6V Lantern I600 Logo
44 people viewed this question
Top Garrity Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
