Question about Philips 42PFL3704D LCD TV
My LCD tv turn off automatically again and again and when we try to turn on it doesnot show picture or sometime it freeze
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 06, 2014 | LG Computers & Internet
MY LG 42" LCD TV
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.Tries again,tv should be working.If still getting no power at all than the tv Tuner board is dead,because pictures freezing and dies completely is the causes so it is not power supply board problems.The tv Tuner signal board is the causes,that the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 17, 2011 | LG 42LC2D 42 in. LCD HDTV
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
The TV doesn't turn on most of the time.
When this happened to us the lamp had burned out so you might try replacing it. After several weeks of waiting for repairs we fixed it in a few minutes.
Feb 02, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have the Sony KV-36XBR400. The picture freezes intermittently. Sound is OK. When I turn TV off and on again, I may get a good picture for about 15mins, sometimes longer. Sometimes half of the screen will...
Hi.. Sorry to hear that the Picture is freezing.. Here are some of the steps that you can try:
*Try to connect a different video source with the TV like DVD Player, Blu-ray player and check.
*If the issue persists, disconnect the power cord and reconnect to a different wall outlet without the Power surge protector.
* If the issue persists, you need to contact the nearest service center to fix this.
Yes, you were correct many LCD TVs have problems compared to this TV.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
37" polaroid lcd tv will not turn on
first try to follow the automatic reset method by unplugging all the wires from the electrical outlet whic connects the tv such as the power cord ,the dvd player or any other devices connected to the tv externally .then plug it after sometime and ON the tv. if the tv doesnot work try this. its the problem in the capacitors and the--- ics--- on the main power supply boards.as some of the caoacitors and --ics--- are blowned out or bulged up on the board and not supporting the tv to start normally.so please check the board and get the faulty one replaced and also check for the blowned out fuses on the power supply board.as the blown fuses can also cause this problem.
Sep 24, 2008 | Televison & Video
Philips 42PFL3704D LCD TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
