Question about Maytag Neptune MAH5500B Front Load Washer
I hear a noise when it spins and in sound like rubber rubbing
  • 101 Answers
Rubber boot at front deformed or something caught there.
Posted on Dec 21, 2013
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Sound from undercarriage when braking
See if the noise is also getting louder as you turn one direction or the other. The rubber rubbing sound doesn't ring bells but I suspect the bearings going out on one of your wheels. If it makes a noise when breaking but get louder or better as you turn one direction or the other I would bet bearings. I would look at that.
Aug 31, 2012 | 2006 Chevrolet Cobalt LS
When driving i hear a sound like im on rough pavement
Could be one of the following:
Old tires. The older they get, the harder the rubber gets, and they will make more and more noise.
Just because they have tread left on them doesn't make them GOOD.
Worn out brake pads. What's left of them is rubbing the rotors or drums.
Bad hub bearings. This is most likely the noise you are hearing. Sounds like you are pulling a trash dumpster behind you.
Sep 07, 2011 | 2001 Oldsmobile Intrigue
Rear driver wheel has light reubbing noise when car in motion goes away when brakes are engaged. Is this brakes or barrings problem? Cost of repair?
hi this sounds like your brake pads have worn, or the brake shoes as well, if you have drum brakes on the back it will be shoes, if disk brakes will be pads+shoes (inside the disk) if it was the wheel bearing you would hear a loud humming noise not rubbing noise, is it a metallic rubbing noise or a rubber squeaking rubbing noise? just check condition of tyre on back if it is the squeaking rubber noise cost will depend on where you take it and if you do it yourself, possibly $40 to $50 at a garage/auto shop or possibly $20 to $30 if you do it yourself, this just depends ...hope this helps
Jun 05, 2010 | 1999 Toyota RAV4
There is a loud rubbing sound when the washer is spinning.
its the main bearings on there way out,,,only thing you can do to stop the noise is to change them for new ones
Nov 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Whirlpool washer functions, but rubbing noise during spins
The pump will make a sort of cyclic "creaking" noise just before it goes bad. You might want to remove the back panel and inspect the drive belt, make certain there are no knicks, loose pieces of rubber or it is slipping.
Let me know.
Regards,
Jul 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
1995 chrysler cirrus
jack up the rear wheel and spin the rear wheel to find out what the rub is. look to see if there is any rubbing marks on or in the fender well.( do not have on the emergency brake) Also if the noise could be metalic then it could be the brake drum rubbing on the backing plate.
May 30, 2008 | 1995 Chrysler Cirrus
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
