Question about Peavey Pv 2600 Power Amplifier
How to run two amps together
Peavey 800 cx
Pv 2600 manual como conectar subwoofer
Peavey service is quite helpful and has most parts in stock for good prices. Call them directly at (800) 752-7896
Jun 22, 2014 | Peavey PV 2600 Power Amp
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
I have 2 peavey 900 Power Amplifiers i would like to link them together was wondering what is the input wattage it can handle?? not wanting to mess anything up!
You CANNOT link the outputs of the amps. They need to drive seperate speakers.
You can tie the inputs together so they will send the same sound to their seperate speakers.
Max power for the Peavey 900 is 900 Watts RMS into a 4 ohm speaker in Bridge mode... That is enough to blow many speakers.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
16 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
