Question about Hardware & Accessories
Where can I find a wiring diagram or a schematic for this charger
A wire has come loose from the setting switch. It is not obvious which terminal the wire goes to since there are so many unused terminals. The wire that has come loose is the white wire from the AC supply power cord. A diagram, schematic, or photo will help.
    Genius:
  • 1,198 Answers
If you can't get the schematic on Google, test between the black wire and the connectors available. One that has continuity with some resistance is a good candidate. One that has no resistance probably is another connector for black....
Posted on Nov 24, 2013
john224
  • 1378 Answers
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
Posted on Jun 13, 2009
protek480
  • 1714 Answers
SOURCE: Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Posted on Jun 26, 2009
  • 112 Answers
SOURCE: Intermatic T103 timer wired for 240V
yes u will, but u will have to make sure one of the motor wires are hooked up that way also, in case it has been moved, here is a link with the diagram u need
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t103%20-%20english.ashx
Posted on Aug 21, 2009
  • 760 Answers
SOURCE: Not sure how to wire my Tork 1103 timer
The L terminal would be for your "hot" incoming black wire. The X terminal would be for your load outgoing black wire. Connect both white neutral wires to the blank terminal (notice this feeds the timer motor. The other two terminals (1&2) are not necessary if it is a 110V single circuit.
Posted on Aug 03, 2010
SOURCE: I would like a wiring diagram for an outdoor
If I understand correctly, you want to add a photocell to existing receptacle.
Start by looking at receptacle:
Receptacle has 3 different colored screws.
Green screw for bare ground wire
Brass screws with black Hot wire connected.
Silver screws with white Neutral wire.
How to wire photocell to receptacle.
Remove black Hot wire off of brass screw and connect black wire to photocell-black wire. This will power the photocell switch.
Connect photocell-red wire to brass screw on receptacle. This will turn receptacle on-off whenever photocell switch turns on-off.
Connect photocell-white wire to silver screw, and this will complete circuit to photocell switch so the switch is able to operate.
All white Neutral wires are connected to silver screws.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 08, 2011
Wiring diagram for 1982 Monte Carlo w/ tilt wheel ignition switch.
A Chiltons/Haynes repair manual has the wiring schematic you need. At least all of the C/Hs I have have the schematics.
Sep 03, 2016 | Chevrolet Monte Carlo Cars & Trucks
1-year old dustbuster black decker cwv1408 will not run unless I slap it on left side.
Your description would suggest either loose wire or a short in the switch. Take the unit apart and check to see that battery terminals are tightly connected.
Jan 02, 2015 | Vacuums
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
2007 electronic ignition
Hi Anonymous, Just make sure all componets in the ignition circuit are tight and have dielectric grease on all their terminals at every connection. Corroded terminals and loose connections are the main cause of all electrical problems. For a free wiring diagram please to visit website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Feb 24, 2014 | 2007 Harley Davidson FXDWG Dyna Wide Glide
Wiring diagram 1992 fatboy
Hi Anonymous, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a test light. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram, please visit the website below. Good luck and have nice day. Harley Davidson Wiring Diagrams and Schematics
Mar 28, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
Wiring diagram for a canal r series switch
There are several R series switches:
http://www.canal.com.tw/images/products/r.htm
Each appears to have terminal, or solder connections.
Electrician uses multimeter set to read ohms to check continuity of unknown switch.
Set to read ohms, and then test each terminal with other terminals, then flip the switch and repeat same test.
Then connect Hot wire to one terminal on the switch.
For example if there are two wires going to a 120Volt light bulb ... then one wire is Hot and the other Neutral. Cut the Hot wire and then connect the two cut ends to switch terminals. So the switch will turn the Hot wire on-and-off.
The neutral wire is not connected to the switch.
May 25, 2012 | Electric Electrical Supplies
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Schematic for EV Warrior Electric Bike
I have a PDF of the schematic i drew for my bike. it is posted on the Yahoo power-assist group. look in the files section.
http://tech.groups.yahoo.com/group/power-assist/files/EV-Warrior/
there is also a text file there that lists all of the wiring connectors and where each of the wires goes. as well as connection diagrams for the Curtis 1505 speed controller.
the charger circuit is very simple. the black and red wires from the charger port go straight to the batteries +24V and 0V terminals. the third white wire connects through a bullet connector to pin#7 (EPO wire) of the Curtis speed controller. this acts to turn off the motors while the batteries are being charged.
inside the charger male connector the pin for that 3rd white wire is shorted to ground. so when you plug the charger in the white wire is grounded thru the charger plug.
have fun. i really enjoyed my EV-Warriors while i could still ride them.
rick
Mar 12, 2009 | Electric Bicycle Motor, Bike,electric...
Micro Schematic diagram
Sharps don't have schematics inside anymore, but I have uploaded the diagram to my site for you.
It's here: http://207.234.249.73/mwd/r510fk_wiring.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
May 31, 2008 | Sharp R-510HW Microwave Oven
Hardware & Accessories Logo
43 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
