Question about Honeywell Truezone HZ311 Zone Control Panel
Red light on honeywell hz311
We have had issues with the Heating unit not functioning recently. Currently, we flipped the main breaker and the heater unit itself off and on. The heater is working again but we are having a red light indicator next to the word heat on the monitor. Is this normal or indicating something wrong? THanks!
  • Hi Victor Sze, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is telling you which zone is open
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
22yooper
  • 828 Answers
SOURCE: My central heating system comprises
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
Posted on May 22, 2008
SOURCE: My Honeywell thermostat T874R is
The above was posted by fixr1st
Posted on May 29, 2008
jeffbvegas1
  • 520 Answers
SOURCE: A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Posted on Jul 11, 2009
Our travel trailer keeps flipping a breaker when we plug in 2 space heaters at a time what could be causing this?
Two heaters may exceed the capabilities of the wiring.
As you say only the plug breaker, move the other heater to that spot to see if the one heater is faulty. Also try plugging a kettle or similar to it. The breaker may just be weak.
If you are using propane heating, it must be a properly fixed appliance, not freestanding heaters because of carbon monoxide poisoning.
Dec 07, 2017 | Heating & Cooling
The dryer is not heating. It will run for a short time but then shuts itself off and the top four green lights will flash. We have thoroughly cleaned the lint traps inside and outside of the machine
Hello Brenda Gibson - Try reprogramming the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 10, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Heater shut down sometime in the middle of the night and now it will not turn on. I checked the breaker box and when I flipped the master switch, it came on for about a minute or two but was blowing cold...
Hi what has happened is, this is a heat pump. The main breaker keeps tripping because the compressor is shorted. I hate to give you this news, but anytime a unit keeps tripping the main breaker on a heat pump, the compressor is either locked up and drawing enough amps to trip the breaker, or it is shorted internally. This is something that you will have to call a tech out on. I am sorry to give you this news, but this is all it could be. If it came on for a minute blowing cold air, the compressor wasn't running due to it being shorted out. This is your only choice is to call someone out to check it. If this is a older unit, you may be better off replacing the outdoor unit. If not, get an estimate on a compressor change out. I wish you all the best on this, and I know this is bad news, but these things always happen at the wrong time of year. Please keep me posted.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Dec 28, 2010 | Carrier 38CKC042 Air Conditioner
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
My samsung refrigerator model RB1855SL is experiencing a temperature sensor issue. The freezer target temp is set to zero degrees and the refrigerator to 38. The unit cools itself down to the target...
We've had tonza problems with ours too, kept building up frost, temperature sensor acted up as well. Piece of trash if you ask me. Never fixed it (did not want to throw money at it). Amazingly we just got a new one... another Samsung.... (with 4 yr extended warranty though this time!)
Oct 13, 2009 | Samsung Refrigerators
Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Jul 10, 2009 | Gaggenau Ovens
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Water not getting hot / Kenmore Economizer 6 / Electric
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
My RCCD unit sometimes trips when I turn my main oven on
I'm assuming you are speaking of the line circuit breaker to the stove. If that is the case and there are ** other problems that you k**w of, it is possible that the breaker has gone bad....they do. Get the same brand and rating as you had originally installed. Cut your main feed and open the terminal panel and remove and replace the unit. Restart main feed and set breaker on. If you continue to have issues, check all wiring to your stove...a loose wire or corroded contact point may be a second issue.
Mar 09, 2008 | Ovens
Oven wont turn off
Turn off the power to the range and contact an authorized technician.You may have a fire producing issue.that needs immediate attention!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 21, 2017 | Kenmore 92002 / 92004 Kitchen Range
Honeywell Truezone HZ311 Zone Control Panel Logo
1,034 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
