Question about Gateway M675 Laptop
Gateway M675 creen problem
A one inch wide band runs from the top to the bottom of my screen almost in the center. The band does not appear on an attached external monitor. It will seem that the problem is with the LCD screen. Any suggestions on how to solve this problem? Thanks. Ntangoh
  • shadoe2k4 May 17, 2008
    I have the same problem with the lcd screen , but the link that was suggested is not available. Can someone help ?
    Sergeant:
  • 457 Answers
Yes you are correct and they are beggars to fix.  Your problem is fixable just ask these chappies:
http://lcdrepair.net
Posted on Oct 10, 2007
SOURCE:
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
I have a gateway m675 and it has something wrong with the lcd screen. In the right hand corner the is a band about 2' wide and runs top to bottom. The colors are inverted looking that area and the tint of...
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Sep 03, 2010 | Gateway M675 Notebook
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Vertical bands on screen
bad x drive board on bottom of set where lines appear
Apr 27, 2009 | Televison & Video
Inch wide vertical white band on my Imac screen?
If the white band appears right from start up, the display needs to be replaced, if it comes on after it starts, it is most likely a software problem.
Feb 16, 2009 | Apple iMac G5 Desktop
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Gateway M675 Laptop Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
