Question about DeLonghi Ovens
Delonghi convection oven won't heat up - DeLonghi Ovens
    New Friend:
  • 11 Answers
No heat at all or not hot enough?
Posted on Dec 14, 2013
  • 1462 Answers
SOURCE: Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
Posted on May 18, 2007
  • 537 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
f the oven doesn't heat and the on-off light works, test the appliance controls, motor,
and heating element .
Posted on Nov 15, 2007
SOURCE: kitchenaid KEBC177 electric convection oven will not heat
This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Oven won't heat up
Hello Michele Smith - If neither elements do not heat but the top of the unit works, then they can possibly be faulty elements or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Nov 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Ovens Logo
138 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Naftali Haskell
Level 1 Expert
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
