Question about Coleman Powermate Powermate 5000W Generator
Not generating any electricity - Coleman Powermate Powermate 5000W Generator
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Check the rotor rings for cleanliness, they should be shiny, check the brushes and the capacitor, located in the end of the alternator bell housing cover
Posted on Nov 25, 2013
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Generator starts up ok. Hooked electric cord to house outlet and other end to generator but not electricity came on.
    Check the position of on/off switches, and circuit breakers that may be interrupting the flow of current.
    Apr 01, 2016 | Gentron GG10020 10,000w Electric Start...
    Lights dim at idle and go to normal if step on gas
    You´re electric generator gets his power from you´re accu when you start you´re car. When driving the electric generator fils you´re accu ! I think you have a problem whit you´re electric generator. In the electric generator are 3 shoes we call them in Dutch. Look of they not waren of !! you can replace them easely
    Mar 08, 2015 | Cars & Trucks
    Generator was running fine and then the electrical output quit while the engine was running.
    Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
    Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
    How do you flash a Coleman Powermate 3500 generator? Runs fine; no electrical output
    See some of my responses to other peoples generator problems.
    If you have no or very little electrical output, then you have overloaded the generator by placing a demand for too many amps from too many appliances for the size of the generator. You will have blown a capacitor, resistor, or similar item. Someone with a good electrical background will need to diagnose the problem and find the blown part.
    Dec 04, 2013 | Coleman Powermate Premium Plus 6250W...
    The generator kicked the breaker of and was smoking and smelled like electrical
    What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
    I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
    Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
    Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
    Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
    Why shuld we save electricity
    The argument for 'saving electricity' is saving at 'peak' times so additional generators don't have to be started up to meet peak demand. The additional generators are smaller, they cost more to run per Kilowatt generated.
    A second argument for saving electricity is so we can continue expanding our economy by adding new homes and businesses, without needing to build another electric generation plant.
    A third argument for saving electricity is your bill is lower.
    The Kvar product you posted under is a scam. If you want to reduce electric bill, consume less electricity.
    http://www.nlcpr.com/Deceptions1.php
    Oct 17, 2010 | Electric Eyeware Electric Saver Save...
    Generator stopped producing electricity
    if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
    Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
    I can't remember if you plug in the generator to the electric panel first (with power turned to the generator and off of the main line feed) and then start the generator, or start the generator and then...
    OK, by talking about a plug, I am assuming you have made a double male plug to hook the generator to the electric panel. This is not really advised, because it is so easy for it to be plugged into an outlet by someone not knowing what it is far, and getting electricuted. Now, away from preaching, and to helping.
    It is best to hook it to the generator and then crank it, so you are not dealing with a load when you plug the systems together. When your power is restored, it would be good to install a plug to your electrical box and have it go to a disconnect like is on your outside A/C unit. It moves you away from the hot wires.
    Hope your power is on soon!
    Dec 21, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
    Coleman Powermate Powermate 5000W Generator Logo
    Top Coleman Electrical Supplies Experts
    John Trevino
    Shawn DuRee
    Phil Walker
    Phil Walker
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
