Question about Singer Featherweight 132Q Mechanical Sewing Machine
My sewing machine keeps bird nesting
Everytime i start sewing my machine stops feeding and the thread keeps birdnesting under the fabric any ideas ??
sew dutch
  • 24 Answers
SOURCE: keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
Posted on May 26, 2009
  • 139 Answers
SOURCE: I have a singer-inspiration machine
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 07, 2010
  • 40 Answers
SOURCE: top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Posted on Jun 01, 2010
SOURCE: Thread is a birds nest under fabric
you can download a free pdf manual at---diplodocs.com
on the first page look to the left for the alphebet letters & find S-- then look for the name singer click on the singer name & it will take you to the second page--on the left toward the middle there is a box that says
most common searches - you will find your model number there- i searched & found it--click on the model number- it will take you to the
third page---they ask you 3 questions about your sewing machine & then let you download the pdf manual
Posted on Aug 05, 2010
  • 1788 Answers
SOURCE: Hello, My 8289 machine keeps
I know that you think that your machine is threaded right, but 99%of the time it is not . You have to make sure that the thread is in discs right, going down the machine . To check it, put your presser foot up, and pull on your top thread, it should move smoothly. Now, put the presser foot down and try it again, it should barely move. Also, put in a new needle, flat side facing to the rear. If, you need a copy of your manual go to www.singerco.com and download it for free. Now, you can enlarge the diagrams of your threading path. Good luck
Posted on Oct 24, 2010
Thread keeps tangling on underside
Called thread nesting or bird nesting.
Install a brand new needle that is compatible with the thread and fabric you are using.
Remove the top thread totally from the machine.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning.
Confirm the thread path is correct.
Retest your machine.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jul 23, 2017 | Sewing Machines
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Pfaff Creative Vision 5. The bobbin thread keeps birdnesting under the plate. I have changed thread, bobbin, dusted and cleaned the machine with canned air.
Just a guess, but do you RAISE the presser foot when threading the upper thread? That will usually stop the bird nesting.
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
Sewing Machine Thread Bunching Up Here Why
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer Featherweight 132Q Mechanical Sewing Machine Logo
78 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
