Question about Air Tools & Compressors
How do I remove the throttle assembly from an ingersoll rand 2135?
My problem seems to be a throttle problem, but I can't figure how the throttle comes apart.
    Habit-Forming:
  • 102 Answers
The throttle valve is housed inside the inlet bushing assembly (item# 26). To remove the assembly there are 2 slots near the bottom of the handle, you will see a metal tip through the slot, that is the clip (item# 27) that need to be depressed in order to remove the inlet bushing assembly (item# 26). There is a special tool to depress the clip but can be substituted by using a small flat head screw driver, once the clip is released, slide the assembly out of the housing and at the very top is the throttle valve (item# 28D) it is held in by a retaining ring (item# 28G). WARNING the throttle valve (item# 28D) has a spring (item# 28C) below pushing up, be careful when removing the retaining ring (item# 28G) it could pop out with some force!
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Posted on Aug 31, 2014
3 Suggested Answers
  • 9 Answers
SOURCE: After rebuilding a Ingersoll Rand 2135- Air flow
There is only a few areas that could cause this. Did you rebuild the valve assembly? If you go to (irtechpubs.com/ir_pdfs/Tools/IR%20Industrial%20Tools/Impact%20Tools/04584033_ed2.pdf) you will see an exploded view of the whole assembly. Note part 28, and then part 28c, this is the valve that controls the inlet air, possibly you have the pin broken off, or the trigger not actuating the valve. Check up the handle for blockage in the exhaust (unlikely). Also check the parts of assembly 29 to make sure nothing is broken, if they are you could have the direction stuck between forward and reverse, thus not allowing air to pass through to the motor (items 10, 11)
Posted on Mar 09, 2010
SOURCE: Have a Ingersoll Rand 2135
i have the same problem, and a fellow co-worker of mine told me about the problem. here it is.. on the handle there are two slots on either side, push them in and the air inlet assembly should pop out along with a broken tiny metal rod.. this rod connects to the inlet valve and turns on and off ur impact wrench.. i have been looking for replacement parts but cant find any.. hope this helps you and maybe help me too..
Posted on Feb 09, 2011
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
Ingersoll Rand model 2135. Gun still runs with the trigger off. Disassembled, but cannot figure how to remove throttle assembly.
Nov 24, 2013 | Air Tools & Compressors
Model number 223
IR 2135-k303 air inlet repair kit along with a 2131-322 air inlet removal tool should get it repaired.
Nov 12, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
Help with air leak problem on Ingersoll Rand Ingersollrand 2135timax
I.R. has a tune up kit available which includes all the necessary gaskets and seals required for this tool.
Follow this link to see the parts list:
Tune up kit P/N 2135-TK2
Feb 17, 2012 | Ingersoll Rand Ingersollrand 2135timax 12"...
Ingersoll Rand 2100G air impact wrench turns when air is hooked up. I can stop it by hand and then use it with the trigger, and it works fine, but it continues to run even when I let the trigger go. What...
The I.R. 2100G shares parts with the 2135 series impact, the throttle valve seal on these models have a tendency to wear out or deteriorate casing the throttle valve to by pass air. On the model 2100G the parts in question is only sold as an assembly (item# 22).
But you can disassemble the inlet bushing and install an inlet parts kit p/n 2135-K303, it includes all the necessary parts.
I will provide to links for you to look at
2100G: http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45667599_ed2.pdf
2135Ti : http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
The I.R. parts list shows the inlet bushing in detail.
Oct 28, 2011 | Ingersoll Rand Air Tools & Compressors
Want to turn when i plud the hose in , and not pulling trigger
YOU MIGHT HAVE A PROBLEM WITH THE THROTTLE VALVE AND/OR THROTTLE VALVE SEAT. THEY HAVE A TENDENCY TO WEAR AND FALL APART. USE P/N 2135-K303 INCLUDES ALL NECESSARY PARTS TOO CORRECT THIS ISSUE.
YOU CAN DOWNLOAD THE OWNER'S MANUAL AND PARTS LIST FROM WWW.IRTECHPUBS.COM
Sep 14, 2011 | Ingersoll Rand Ingersollrand 2135timax 12"...
I have a ingersoll rand 231c 1/2 impact wrench that is almost brand new, have had no problems with daily use until today when the trigger will not move.
The IR231c is equipped with a throttle valve stem (item # 9) that is prone to oxidation and causes a stuck trigger condition. Remove the air strainer assembly (item # 10), followed by the spring (item # 8) then the throttle valve (item # 6) you will see the throttle valve stem (item # 9) spray some penetrating lube, if severely stuck it may be necessary to remove the trigger and pushing the throttle valve stem from the top.
Follow this link to see the parts diagram.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584546_ed3.pdf
May 26, 2011 | Ingersoll Rand 1/2" Super Duty Air Impact...
Air Tools & Compressors Logo
154 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
