Question about Copystar Kyocera Fs-3140mfp fs-3140 Copier
Message . match the position of envelope switches
How to fix match envelope switches?
On the FS-4000, this message can be cleared by releasing and pulling out the rear unit until it stops and making sure that the green pressure buttons on both ends of the fuser unit match. Both buttons depressed indicate envelope mode. Both released, indicate normal paper mode.
Sep 08, 2015 | Kyocera Fs-4000dn Workgroup Laser Printer...
Duplex printing FS-2100D
in back of machine there is a fuser unit there are 1 or maybe 2 small green buttons or switches on it that is the envelope setting push the button or switch to put it back in normal paper mode
Sep 14, 2017 | Kyocera Office Equipment & Supplies
The problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
the problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
Feb 24, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Describe your KYOCERA FS2020D Match envelope Problem the printer is stating MATCH ENVELOPE SWITCHES?
Load the status moitor utility and using that you can set the bypass paper size to match the envolpe size you are using.
Dec 13, 2010 | Kyocera FS2020D ECOSYS Monochrome Laser ...
"match envelope switches" error message. cannot remove it. cannot bypass it. printer is unusable. urgent. already down one entire day, students (and myself) are climbing the walls. Thank you for any...
Open the back side of the printer. There are 2 buttons for the envelope. Switch them so that they are at the same position for normal paper. See also manual. It's described there.
Sep 29, 2010 | Kyocera Office Equipment & Supplies
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Envelopes trigger ''wrong paper size'' every time in hp 1510
Have you made sure to choose the correct (matching) envelope size in your software?
Dec 01, 2009 | Office Equipment & Supplies
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Envelopes won't print
    Whichever application you are using for printing envelopes must have a set up icon and set, in options, for envelopes
    That will show in which position your envelopes will be, when being transported through the printer. Like, print side up, right side of transport, and like that.
    Make sure you haven't bypassed this, and be certain that the pass through matches what the printer expects when printing envelopes
    My Word 2003, when using an InkJet printer, expects it on the right side, print up. When using my color LaserJet, expects to see the envelope in the center, print side down.
    I hope this helps,
    -a.
    Jun 30, 2009 | Brother MFC-640CW All-In-One InkJet...
    Copystar Kyocera Fs-3140mfp fs-3140 Copier Logo
    177 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Kyocera HP Expert
    CheckitRight
    CheckitRight
    Scott Yeoman
    Level 1 Expert
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
