Question about Reliance 1995 Chevy Cavalier Pontiac Sunfire V4 2.2l Alternator
Head bolt torque specs - Reliance 1995 Chevy Cavalier Pontiac Sunfire V4 2.2l Alternator
  • 827 Answers
You can go on line and look up head bolt spec for your car
Posted on Nov 24, 2013
Torque specs 2003 olds silhouette rocker arm 3.400
Here is a suggested updated torque spec for this engine's rocker arm bolts;
Rocker arms
Step one: Torque to 11 ft lbs then tighten an additional 90 degrees of bolt head rotation. Some guys don't fuss with the torque specs and just get them good and tight. Either way, be careful, as the heads are aluminum. You do not want to over tighten these bolts
Oct 07, 2016 | 2003 Oldsmobile Silhouette
Can anyone.tell me the Torqe specs for a 2004 or cruiser
Head and Cam Bolt Torque specs? - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 5, 2012 - 2 posts - ‎2 authors
I am putting everything back on after replacing the head gasket. I was wondering what the Torque Specs and Sequences are for both the Head ... Torque Specs
Jul 28, 2012
Valve cover torque specs
Jul 4, 2011
Timing Repair Project - Bolt Torque Specs
Jun 16, 2011
torque specs?
Mar 20, 2006
More results from www.ptcruiserlinks.com
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts ...
? 5:07
https://www.youtube.com/watch?v=2wB2o27eWgo
Aug 20, 2015 - Uploaded by World Mechanics
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts Install and Torque Specs 2.4 Engine. ... 2004 Chrysler PT CruiserCamshaft Install
Dodge Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head ...
? 6:08
https://www.youtube.com/watch?v=7rY7tDbye-8
Aug 16, 2015 - Uploaded by World Mechanics
... Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head gasket Install and torque specs We took this video to ... 2004 Chrysler PtCruiser head gasket
Jan 18, 2016 | Cars & Trucks
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Torque spec
Head bolt torque is 32 ft.-lb. (43 nm)
Head cover bolt torque is 7 ft.-lb. (10 nm)
Mar 25, 2010 | 2000 Yamaha Royal Star Venture
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Aug 16, 2009 | 1999 Ford Escort
Need to find specks on cylingder head for 1996 toyota tercel
The cylinder head bolt torque is a 2 step process.
First: Torque all of the bolts to 45 Nm (450 Kgf-cm or 33 ft lbs.)
Replace any head bolt that will not torque to the above specs.
Second: after all ten bolts are torqued to the above specs, the head bolts are then "Torqued to Distance"...
Starting at the center bolts, retorque all ten bolts an additional 90 degrees.
Hope this helps, the graciousness of a FixYa rating would be greatly appreciated.
Jan 21, 2009 | 1996 Toyota Tercel
Reliance 1995 Chevy Cavalier Pontiac Sunfire V4 2.2l Alternator Logo
293 people viewed this question
Top Reliance Electrical Supplies Experts
GFTALON
wadingriver
wadingriver
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
