Question about Vacuums
Miele powerbrush The powerbrush starts, but then stops turning after 5 seconds or so. it is clean, maybe it is a motor problem?
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Posted on Mar 29, 2008
odiebugs
  • 949 Answers
SOURCE: Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Posted on Mar 24, 2009
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Miele vacum motor dead
would need more info to really isolate problem but you either need new cord reel, speed control board, or new motor. maybe all three. either way a make and model number would help
Apr 02, 2013 | Miele Vacuums
Mar 24, 2009 | Miele SEB 213-2 Vacuum
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
My Miele vacuum carpet head will not work. It is an SEB236 Powerbrush and the "reset" light is on when I turn on the vacuum. I don't know what this means! Please help!!
If the light is on then you must be getting power to the power head. Could be a motor problem, there is a push button switch and a circuit board. Just have to checked to find the problem.
Mar 13, 2008 | Vacuums
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
