Question about Locks & Locksmithing
Remove penncraft door knob lock
Remove door lock
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
Cant get knob off to install door lock
Dont have an answer, but have same problem. Any thoughts ?
Jan 05, 2014 | Master Lock BAO0103T Keyed Entry Door...
The lock got flipped on the bedroom door. I am now locked out. The door knob has been removed but I cannot get the mechanism inside the door unlocked. How can I do this?
You are almost there. Take the knob containing the spindle and insert into the latch mechanism. Twist it and the lock button will pop out. Open the door. Put everything back together. NOTE: I just confirmed this using a lock mechanism in front of me as I answered this.
Nov 09, 2013 | Hardware & Accessories
Bath room door knob is locked. How do I unlock it?
Remove outer knob with push pin, unscrew fromm door and remove there is a pin latch in side (looks like a loop of wire ) flip to top or bottom will matter if left or right hand door.
Feb 04, 2011 | Top Knobs Round Knob - Brushed Satin...
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
2000 cadillac deville remove door panel
2000-2001 Deville Door Panel Removal:
1. Position window fully downward and ensure manual lock knob is in unlock position.
2. Disconnect locking clip at front of manual lock knob, by insertingsuitable flat bladed tool into top service notch.
3. Remove manual lock knob.
4. Remove inside handle bezel by holding inside handle to open position, inserting sutiable flat-bladed tool at front lower corner and prying outward.
5. Remove bezel.
6. Remove inside door handle mounting screw.
7. Disconnect eight retainers around outside edges of door trim panel using clip zip tool No. J-36796, or equivalent.
8. Slide door trim panel upwards to release alignment datums, eight retainers, armrest steel retainer clips and inner belt mouldings (see fig #7 amd #8).
9. Disconnect electrical connector(s).
10. Reverse procedure to install.
Hope this help (remember rated this).
Mar 28, 2010 | 2000 Cadillac DeVille
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
1992 corvette Lt1
You have to remove the door lock knob to get to the screw. Make sure door is unlocked,then you take an pull the knob outward til pops off.Then you should be able to remove the screw.
Oct 19, 2008 | 1992 Chevrolet Corvette
Locks & Locksmithing Logo
50 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
