Question about Polycom SoundPoint 330 IP Phone
Connect to sagemcom f@st 2864
Phone does not recognize internet and modem does not recognize phone
    Top Expert:
  • 12,223 Answers
1) reset the phone to the original manufactury default see your Menu AND do it 2) call to the supplier manufacturer Modem, and get the support via ONLINE chat for to fix it.
God bless you
Posted on Nov 25, 2013
Ipad2 dropping connection. I have a Sagemcom 1704 n modem. Laptop and iPhone working great.
if you have dual band,use 2.8 ghz instead of 5.6ghz,or the power adapter to your modem is not giving enough power,also update your ipad by searching for updates
Apr 20, 2015 | Computers & Internet
Polycom 330 cannot connect to internet through sagemcom modem
see the diagram attached, However you must call or go to the website from your supply in both cases,and get the support via ONLINE chat and fix it.
God bless you
Nov 24, 2013 | Polycom SoundPoint 330 IP Phone
I want drivers to use my phone as a modem on win vista.
Click on the link below to download the Software for your Phone to access internet on PC
Download Link 1
Download Link 2
Ways to connect or access internet below :
When you connected your Diamond to your PC, what did it get recognized as?
What does it show up as in your PC's Device Manager?
On your device, do you have Internet Sharing or Wireless Modem? If it is Wireless Modem, after you connect your device to your PC, you Start Wireless Modem and that should install the Modem Drivers.
If you have Internet Sharing, what is the message you get on the device after tap connect (Check USB, Disconnected, etc.)?
Try updating active sync software to the latest, at least 4.5 I'd think. Not sure if there's a newer version out.
Also,
Connect your phone to your pc by using the USB cable provided with your phone. On your phone you should go to Window Icon at top left corner of screen, then go to Programs on the drop down menu. From there choose Internet Sharing. Once you tap Internet Sharing you will be prompted at the bottom left of the screen to Connect. Tap Connect and then you will see your pc recognize the connection on the bottom right of computer screen. It will install the drivers and then from there you are good to go. Hope this helps!
Thank you for contacting FixYa
Nov 24, 2010 | HTC Touch Diamond Smartphone
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
I have a problem while connecting from mobile to pc for internet browsing.i have a samsung sgh-l700 set&with bsnl connection...
>>make sure that your phone is set up with your pc, and recognized as a modem, i;e ; sgh-l700 samsung mobile modem. and you have set up your mobile phone for internet connection. it can be seen in the network folder.
now try these.
1. check your phone if it can connect to web through your internet phone browser,just select from the menu of your phone, internet, select home, if it can connect and it open to its home page, then you are really set up for your connection.
2. open your control panel, select phone and modem options, you will see your samsung mobile phone there., select properties, select advance and enter this '' extra initialization command AT+CGDCONT=1,"IP","celloneportal"
3. select apply and ok, and close your control panel.
4. open your network folder, select your samsung mobile modem,right click it and select connect.
5. try to check.
Feb 18, 2010 | Samsung SGH-L700 Cell Phone
I want my pc to connect with internet via bluetooth of mobile phone but a dialogue box appears with the message that "modem is removed"
Hello, Not knowing the brands or models of your pc and mobile phone, for that you nedde that your pc recognizes the modem that your phone has inside of it. Usually, first install the software on the pc, then connect the phone and watch what happens. Should load/recognize the modem in your phone. You can always perform a software update for your phone and try it again. Regards.
Jun 08, 2009 | Compaq Presario Notebook
USB external modem
The phone connection would need to go through the blue tooth regardless of if you're using the phone connection or not. Check to see that you have bluetooth turned on and setup first. Then you'll need to use that to create the settings for using the phone as a modem. However, if you are using Windows on your Mac, you will need to make sure that your computer has the drivers installed to be able to both connect to the Internet and to connect to your phone. Once that is set up, you still need to go through the steps to use bluetooth to connect your phone to your computer, establishing a connection. There are quite a few articles about creating connections through your phone as a modem. http://mobileoffice.about.com/od/typesofaccessavailable/ht/bluetoothphone.htm
http://www.theinternetpatrol.com/how-to-connect-your-computer-to-the-internet-using-your-cell-phone-as-a-wireless-internet-connection-or-tethered-modem
Mar 01, 2008 | Apple MacBook Pro Laptop Computer with...
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Nov 08, 2007 | Computers & Internet
Open Questions:
See all Polycom SoundPoint 330 IP Phone Questions
Polycom SoundPoint 330 IP Phone Logo
155 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
