Indesit Widx126 not drying, checked element which is ok, dryer motor does spin, does anyone know if they have poblems with dryer motor not spining fast enough or blockages anyware(ducting where element is gets hot but drum remains cool) thanks
    Genius:
  • Washing Mach... Master
  • 2,341 Answers
-Possibly broken exhausted fan or outlet vent is block.
Mai
Posted on Dec 21, 2013
4 Suggested Answers
  • 1462 Answers
SOURCE: washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Posted on Jun 03, 2007
vest6
  • 196 Answers
SOURCE: broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Posted on Jan 08, 2008
  • 25 Answers
SOURCE: Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Posted on Apr 07, 2010
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Machine does Agitate
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
